Question about Panasonic DVD-RV45 DVD Player
Dvd rv 40panasonic
Disc tray keeps opening and closing,wont load or play
SOURCE: DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Posted on Jan 16, 2008
  • 47 Answers
SOURCE: Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Posted on Mar 09, 2008
SOURCE: Locked dvd tray.
try this steps I think it will solve your problem.
Posted on Jun 28, 2008
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
  • 16 Answers
SOURCE: XBox 360 disc tray open
i have the same problem i called xbox and they said that it needs a new disk drive and it would be 100.00 so if you want it fixed youll nedd to call 18004myxbox and they will give you all the info on were to send it or for 100.00 more you can buy a new one like i did
Posted on May 03, 2009
  • 46 Answers
SOURCE: wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
Posted on May 12, 2009
0 characters
1 Points
LG DRT389H will switch on OK but the disc draw will close when a disc is loaded, but comes straight out again and will not play.
There is a loading motor and a belt associated with it, connected to a gear wheel assembly that pulls in the disc tray as well as gets it out. If the loading belt, said above, will get loose, the disc loading tray wont get into it properly. There is a sensor switch fitted inside the loading mechanism, which senses the proper tray in action, as this tray will touch it when it ahs been fullly loaded. Due to any reason, the switch said above does not engaged properly, the main system control IC will detect the loader position to be improper, and will give command to eject the tray. That is now happening to your DVD player.
If you have knledge and experience, just open your DVD player. locate the loading belt, and repalce it with a new one. You can buy this belt from most of the electronic sparepart selling shops at your town. Just keep the old belt in hand as a sample, when you go to buy a new one. OK
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 27, 2011 | DVD & Blu-Ray Players
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Jun 22, 2011 | Sony DVP-C670D
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Does not play when disc entered nor when play is selected. (XD-E500KB)
Push in the plug connected to the "Video Out" jack on the rear of the Dvd to ensure it is connected firmly. Check the connection at the back of the TV as well.
Press the "Source" or "Input" button on the TV remote to verify the television's input is set to the DVD connection.
Press the "open/close" button on the front of the DVD to open the disc tray. Insert and test different DVDs to determine if the problem is with a specific disc, or if the player will not operate.
Eject the DVD tray and insert the DVD laser lens cleaner. Close the tray and wait a few seconds for the cleaning disc to load. Press "Play" on the front control panel to spin the disc through the cleaning cycle.
Remove the cleaning disc, insert a DVD and test playback operation. If the machine still will not play discs, the main receiver unit may require internal repairs best left to an experienced technician.
Feb 02, 2011 | Toshiba DVD & Blu-Ray Players
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Panasonic DVD-RV45 DVD Player Logo
29 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
