SOURCE: can not install java apps on my lg shine ke970
Have you looked at this bog site
http://www.consumingexperience.com/2007/04/lg-shine-ke970-phone-ringtones-music.html#java
it suggests putting both jad. and jar. files on the phone together
SOURCE: Installing jar files on samsung i300
in order to install a java application u need two files one is JAD and other is JAR some phones require both and opening the jad file will install the program.. transfer both jad and jar file onto same folder and then install
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
SOURCE: UNINSTALLING KODAK EASY SHARE SOFTWARE and removing it on my system
im having the same problem.
