If you are having trouble pairing your Graco WiFi baby monitor to your phone, there are a few things you can try:
Check the distance: Make sure that your phone and the baby monitor are close enough to each other to establish a connection.
Check your WiFi: Make sure that your phone is connected to a stable WiFi network and that the baby monitor is connected to the same network.
Check the firmware: Make sure that your baby monitor has the latest firmware update.
Restart the monitor: Try restarting both the phone and the baby monitor and then try pairing them again.
Check the manual: Make sure you are following the correct pairing instructions, refer to the user manual or the manufacturer's website for guidance.
Factory reset: If the above steps don't work, try factory resetting both the monitor and phone, and then try pairing them again.
Contact manufacturer: If the problem persists, contact the manufacturer for further assistance or check if it's still under warranty.
It's important to note that the steps may vary depending on the model, firmware version and the region. It's best to check the manufacturer's manual or online guide for specific instructions.
the manual covers pairing
read the headphone manual it tells you what buttons do the pairing.
are you asking us to read to you? or how to find samsung.com
Normally when pairing with any device, any pairing code can be applied (4 digits),and then when asked on the other system, the one applied on the first system, will be required to put in. In most of the cases, it is pre defined as 0000
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
Default pairing code for Bluetooth device(s) is 0000 or 1234. Note that some devices don't have a pairing code, so whatever you set up on one device put on the other as well.
Have you tried pressing the pairing button at the back of the camera unit and press the scroll button at the center of the receiveing monitor at the same time as suggested by the manual? I had the same problem, followed the manual instructions and solved it. (Greetings from Mexicali, M
Wireless mice usually work via radio frequencies commonly referred to as
RF.this is also the case with bluetooth technology.so if your mouse is a bluetooth mouse you may need to run the software to make the mouse communicate with your PC.another issue is pairing (coordinating your mouse's transmitter with your mouse's receiver. It
requires both parts to operate on the same frequencies, usually by using
the same identification code. Pairing takes place to try to eliminate
interference. Some devices automatically pair both devices at start up;
others need to be manually paired by entering the same codes on both devices.once both devices are paired they will generally communicate with each other.best of luck.
