Press Menu until "Fax Setup" appears on the top line of
the display.
The first available menu item, "Default-Change", displays
on the bottom line.
2 Press the scroll button ( or ) until you see the desired
menu item on the bottom line and press Enter.
If you select "Default-Change", you will see "Resolution".
Press Enter again.
3 Use the scroll button ( or ) to find the desired status or
use the number keypad to enter the value for the option
you have selected.
MSG Confirm
You can set your machine to print a report showing
whether a transmission was successful, how many
pages were sent, and more. The available options are
On, Off, and On-Err, which prints only when a
transmission is not successful.
Image TCR
You can prevent the Image TCR from being included in
the confirmation report for privacy or security
protection. The available options are On or Off.
4 Press Enter to make your selection. The next Fax Setup
option appears.
5 If necessary, repeat steps 2 through 4.
6 To return to Standby mode, press Stop/Clear
SOURCE: how to set fax confirmation on Samsung SCX-4521F
Link to download manual for instructuions:
http://www.samsung.com/us/support/download/supportDown.do?group=printersmultifunction&group_cd=&type=printersmultifunction&type_cd=06010000&subtype=monochromelasermultifunctionprintersfaxes&subtype_cd=06010300&model_nm=SCX-4521F&dType=D&mType=&model_cd=SCX-4521F/XAA&menu=download&menuLink=/support/download/supportDown.do&prd_ia_cd=06010300&disp_nm=SCX-4521F&isEqualsY=
SOURCE: my printer is samsung scx4521f, there is no dailing tone
aap ka free diver kis site par milegi -----samsung scx4521f
SOURCE: how to send a fax through samsung scx4521f?
Hi. I think its best to consult the manual. Go to this link:
http://www.samsung.com/au/consumer/detail/support.do?group=printermultifunctionfax&type=printermultifunctionfax&subtype=monomultifunction&model_cd=SCX-4521F/XSA&mode=C
SOURCE: samsung scx4521f saying scanner locked
under the operations panel, where the copies comes out there is an optic lock. You need to unlock it.
