Question about Acer Aspire 3000 Notebook
Acer aspire 3000 no power up
No lights, no beeps ,nothing!
Laptop is Just over 1 year old.
I tried using a known good power supply and still no bootup or anything .
Also with battery out too, still nothing either way.
Thinking there must be something in the circuitry gone bad?
Any ideals as to what part usually goes out on these ?
Thanks for your input
  • Jim UnTold
    Jim UnTold Nov 14, 2007
    I am not having any luck accessing the cmos clear or battery on the Motherboard .
    I am trying to get a manual showing more details on how to remove the assembly ,
    I am so close to having access but there seems to be something left to untighten close to the DC power jack
    Thanks for your input friend
    I will let you know ..if I gain access and if it worked or not
  • waddenj1 Feb 11, 2009
    I cant get mine to show any signs of life, even when i plug it in. it shows no lights and no sound. why?
Had the same problem , took out the Ram stuck it back in again and all was fine or try using a different module .
Posted on Mar 06, 2009
Remove the two nuts from the external monitor port right next to the power jack. Just wiggle the motherboard out. That should do the trick.
Posted on Aug 22, 2008
  • 121 Answers
Try to clear cmos by changing the position of its jumper ( while power is off) near the batery in the mainboard then return it to its position.
Posted on Nov 12, 2007
  • 324 Answers
Follow this link and it will take you to a disassembly guide for the Acer 3000 series. But it is pretty basic and I think you may be past the points that it covers. There is also a note with a link in the top section to get to the service manual. This only gets you chapter 6, which is an exploded parts view with a list of part numbers. Maybe that link will be of more help.
Will keep looking for you!
Posted on Nov 14, 2007
I have an Acer M1640 for about a year now, and all of sudden the monitor is not detecting i have tried to removing CMOS battery on motherboard, tried powering ON with RAM removed and i got the unending...
Acer computers are known to have low quality Power Supply's.
The one in your Acer could have a weak voltage power rail. No, not something that is easily fixable. It's more intelligent to replace it with a KNOWN to be good, Compatible power supply for a test.
1) Monitor not detecting.
In otherwords, No Signal. No video signal because the computer isn't working. LED lights may light, perhaps fan/s spin, but there isn't enough power to turn the Processor on.
A) ALL of the LED lights on at once use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
Intel Pentium Dual Core E2160? Can use Up To 65 Watts,
[ TDP = 65W
Thermal Design Point.
65 Watts ]
Known to be good, Compatible power supply:
The Acer M1640 desktop computer just uses an ATX form factor power supply. The kind installed in over 80 percent of desktop computers out there.
Form Factor is a term used for motherboards, but has gone on to other various computer parts.
It refers to the size, and shape of the Power Supply's case, and the power cables the power supply has.
Size and Shape:
Approximately 6 inches Wide, 5-1/2 inches Long, and 3-1/2 inches Tall.
Power Cables:
1) 24-pin ATX main power cable,
2) 4-pin ATX +12 Volt power cable,
3) Should have at least 2 SATA power cables.
4) Should have one 6-pin PCI-Express power cable.
5) Two to Four, 4-pin ATX standard Peripheral power cables,
{Misnomered as Molex. The name Molex stuck, just like Crescent wrench did for an open-end adjustable wrench }
[ The links to power cables above are part of a main page. Scroll up to the top of the page, and click on the photo - SATA power cable, for more info on SATA power cables ]
Perhaps there is an unused computer, that you can borrow it's power supply for a test unit.
The Acer M1640 just uses a 250 Watt power supply. (ATX form factor)
(If the power supply has more Wattage it's okay.
A Computer ONLY Uses the Power it Needs, and No More.
If you installed a 10,000 Watt power supply, {Exaggeration}, and the computer only needed 100 Watts for what it was doing, it would ONLY use 100 Watts, and No more )
Would like to hear back from you. Post in a Comment.
Sep 01, 2011 | Acer Aspire M1640 Refurbished Intel...
Not charging acer aspire 3081 tz, "plugged in not charging" 8% , when disconect power plug, it shuts down. works normally with plug in,with or without battery. one year old. also. not...
Try flashing the BIOS of your machine by downloading the update from the website of your computer manufacturer.
If that does not work other troubleshooting steps to try are:
1. Use a known good working adapter from another laptop that matches yours. 2. Try another battery.
Hope this helps!
Jul 16, 2011 | Acer Aspire One PC Notebook
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
Acer black screen no beep with memory taken out
Check if you have image connecting an external monitor to laptop.
Oct 17, 2009 | Acer Aspire 5100 Notebook
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
Acer aspire sudden death my acer aspire L100 can't boot, only the noise of the fan and the DVD player. nothing else can anyone help please ?
Dear sir
if u don't get eny display 1 you need to cleane RAM then it's still not working you need to chek power suply.. and chek yr cables is attached is right or not.
simple.. if u need more help please contact feel free.. thianks..
Dec 15, 2008 | Acer Aspire L100 PC Desktop
Acer Aspire L310 - Will not boot, will not beep
remove the power cord from the back and take the side panel off, take the memory and out clean the modules and the slots that they go into, if there is more than 1 put them back in 1 at a time rebooting the pc each time to see what happens
keep me informed
Nov 22, 2008 | Computers & Internet
Completely dead
Check the power adapter connection or the socket. Recently my power adapter socket gave me the same problem. When I check from the adapter using voltmeter it's seems to be working.
But when i plugged it in the laptop, nothing happens. So I google around for help and found this tutorial after following the suggestions I managed to revive my notebook.
Mar 20, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Power Issues
In this case myself assume that your acer do a problem in the memory, try remove and clean the memory.
1. boot your acer without the memory. hear beep? if yes,
Only memory has a problem, if no, then;
examine the mainboard of your acer.
If you can hear a beep then fix back the memory and start the system.
if this not solve the problem, replace the memory.
In case that it hard for you to open the laptop let the repairman do it for you so that all your problem will be examine.
Jan 22, 2008 | Acer Aspire 3000 Notebook
No power
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Computer Power Supply Information Because of these precautions, no extensive information will be found on this page about opening power supplies.
No display on monitor. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several
Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 3002LCi Notebook
Acer Aspire 3000 Notebook Logo
3,984 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
