Question about Iomega (33600) 160 GB USB 2.0 Hard Drive
Does not read
My !60 GB external hard dirve does not read on my computer.
What can I co to retrieve the data?
  • 99 Answers
This depends on how much the data means to you and what the problem is with the drive. With the external hard drives it could be a problem with the board inside that converts the signal which could be fixed by removing the drive from the case and connecting the drive either directly to an IDE connection inside another computer or by connecting it using a different drive carrier. If the drive works but the data is not there any more you would need to get some data recovery software that will read the drive and re build the data. There are some really good data recovery software packages that are free for personal use. If the drive does not work at all the only real option that I can give you is to bring it to a place that does professional data recovery where they may be able to get the data without charging much money but more than likely if it comes to that point you should probably be expecting costs in the thousands of dollars.
Posted on Nov 12, 2007
Can the data be retrieved from this device if it wont switch on?
What device are you talking about? Is it a computer hard disk, laptop hard disk or external hard disk, or SSD's.
Data can be recovered or retrieved when the media device/storage device is not in working conditions. This data can be retrieved with the help of data recovery experts. They experts have tools and devices that can help you to regain the data.
You can check
Stellar can recover data from all media devices and guarantees up to 95% data recovery
Apr 23, 2016 | Power Computers & Internet
Unreadable external hard drive
I would suggest
They offer both online data recovery and do-it-yourself data recovery services.
Sep 07, 2012 | ADATA A-data Sh93 Portable 500gb 500 Gb...
How to reformat a external hard drive to ntsf
Insert the USB hard drive into the PC's USB port.
Go to Control Panel - Administratve Tools - Compurt Management - click on Disk Management - scroll down and click on the external haqrd drive, delete the HPFS partition (this is the MAC file system), create a new partition NTFS - format this partition.
If you want to use this external dirve to exchange data between the PC and the MAC the format this hard drive in FAT32.
The MAC can read and write files in FAT32.
Apr 16, 2012 | MicroNet Technology miniMate MM80 80 GB...
Hard disk not detected - Need to retrieve data
If it is your system drive (C:)
You can remove it and try connect to another computer (internal or in an external caddy).
Usually you can get the information you need like this.
Jul 23, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Simpletech 250 GB Pininfarina was knocked on the floor
oped it, maybe loose cables or connections. or the worst case, a faulty hd. ticking sound means bad drive, cannot read disks. retrieve data? the better chance will be a recover technician, dont try anything else, will turn a worst problem.
Jun 02, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
My computer can not find my second hard dirve. The drive I am tring to hook up is from my external hard drive. Some components of the external drive don't work however the hard drive is still good. I know...
go to the device settings and try to find it by scanning the usb port.when he removed the info was it still in the case .if not the problem is with the usb out-put board in side the unit.
Dec 08, 2009 | Western Digital 250GB MyBook External USB...
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
Have you looked both in Device Manager and in Disk Management?
Have you tried plugging your external hard drive into another computer?
If it isn't recognized on multiple computers, then you are probably experiencing a hardware failure.
There are a variety of things that can malfunction on your external hard drive:
1) The USB cable - Have you tried switching the USB cable?
2) The external hard drive casing
3)  The hard drive itself
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on our website.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within the warranty period. For specific warranty and replacement information, go to and click on Support.
Have a nice day,
I/O Magic Technical Support
Jun 15, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Iomega (33600) 160 GB USB 2.0 Hard Drive Logo
212 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
