This could be a Samsung WF45T6000AW washer. On this model (and most similar recent Samsung front-load washers), the dispenser drawer is to the left of the cycle selector dial. When you pull out the drawer, the compartment arrangement is: front left - liquid detergent, front right - liquid fabric softener. Liquid bleach goes into the back compartment. If you are using a powdered detergent, you have to remove the liquid detergent container. It just lifts out. Then put the powdered detergent in the front left- compartment.
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
Do you use liquid laundry detergent & liquid fabric softener? If you do then this could be the source of the residue that is getting on your clothes. Over a period of time the gummy residue from liquids will accumulate between the tubs. You can clean out the washer with a product called Washer Magic or the unit will need to be disassembled & cleaned thoroughly by hand. Do not let raw liquid detergent or fabric softener come into contact with your clothes. Also, here is a link to the agitator cap if you should need it.
Hello, Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer. Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor. Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
1. Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
