There could be loose connection, Check the same adapter with the known good unit>If that works fine with the diff unit , which means the charging port must be lose. If that acts in a same way on diff unit as well, you can try replacing the adapter
the connector in the computer is connected to the mother board and it tends to crack (design flaw) thus the connection becomes erratic solutions are 1)replace mother board 2) if you know someone really good at pc laptops and slodering u open laptop dismantle and sloder connections 3) replace laptop 4) unfortunately live with jiggling until it charges
Internal GPS port? Is there a comm port asigned to the internal GPS that I can use when installing...
(More)
Internal GPS port? Is there a comm port asigned to the internal GPS that I can use when installing marine apps that use NMEA information? Don't see any obvious GPS hardware under Control Panel System Hardware... Thanks! Don
I have a Goodmans Laptop which has developed a problem. I now need to re-install Windows XP but no...
(More)
I have a Goodmans Laptop which has developed a problem. I now need to re-install Windows XP but no longer have the discs. How can I achieve this please? The model Number of the Laptop is Green553. Thank You
