I'm trying to wind my bobbin on the Janome HD1000. The manual says to hold the hand wheel and turn the stop motion knob, but they don't seem to move independently of one another. Could it be stuck? How do I fix that?
The drive belt only brings power from the motor to the mechanism driven by the hand wheel. Some machines have more than one belt; the other belts are part of the stitch selection mechanism. However, I'm not sure about your model. http://www.searsarchives.com/history/files/sewing_id.pdf lists a 158.492 and a 148.392 but no 153.392. A more likely issue for an older sewing machine is that the stop motion mode is engaged. This disengages the needle bar connection. Does your machine have a knob inside the hand wheel? If so, hold the hand wheel and turn the knob away from you (clockwise). For other machines, check if the bobbin winding mechanism needs to be moved to the left. If these aren't the case, then a linkage between the hand wheel and the needle bar isn't connected properly. The machine would need to be disassembled to find the problem. For any machine with a computer control, this is best done by a sewing machine repair technician unless you have experience with repairing electronics.
I hope this helps. Please add a comment if you misread the model number for further assistance on how the bobbin winding mechanism might be stopping the needle bar. I have assumed that you can freely turn the hand wheel.
The Pfaff 332 has a stop motion mechanism that is a small knob in the middle of the hand wheel. This disengages the needle and allows you to wind the bobbin without having to check on the material to be sewn. Hold the hand wheel so that it will not move. Turn the stop motion knob counter-clockwise (turn the knob all the way to the left). Put a second spool of thread (of appropriate weight and color) on the right hand pin. Lead the thread from the spool around the thread retainer clockwise. Pull the thread into the guide and then push the thread through the slot in the bobbin from inside the bobbin. Place the bobbin onto the bobbin winder spindle so that the key at the base of the spindle enters the slot in the bobbin. Press the lever into the bobbin. Hold onto the thread end and slowly start to wind the bobbin. After a few winds of the thread, break off or cut the thread that is above the bobbin. Continue winding the bobbin (at any speed). When the bobbin is full the lever will automatically move back to its original position. (If you do not need a full bobbin, move the lever when the bobbin is sufficiently full.) Remove the bobbin from the bobbin winder spindle and cut it free of the spool thread. Return the stop motion mechanism to the right by turning it clockwise while holding the hand wheel.
You probably didn't disengage the sewing machine mechanism. Hold the hand wheel steady so that it will not move with one hand. Use your other hand to rotate the knob in the center of the hand wheel towards you. When the unit is properly disengaged, the motor can't move the needle bar. When done winding the bobbin, you need to hold the hand wheel and then turn the knob away from you. See page 9 of the manual for the Creative 1471. Pfaff has the manual on the product page: http://www.pfaff.com/en-US/Machines/creative-1471 . The current link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/creative1471-manual-EN.pdf .
Singer indicates that the 2430 to the Merritt 2404. The Merritt 2404 manual is available on the Singer support site: https://www.singer.com/support . The current link to this manual is https://www.singer.com/sites/default/files/product_manual/9bb8bc029ac33374a16f6ef37fdb37c14c7a8356_0.pdf . To wind the bobbin, make sure that the needle is up and lift the presser foot. Hold the hand wheel with one hand and keep it from moving. With the other hand, loosen the knob in the center of the hand wheel by turning the knob towards you. If the thread is not already on the spool pin, place it on the spool pin with the thread retaining slit to the right. Put the spool holder on the spool pin so that it holds the spool firmly.
Next snap the thread through the thread guide post and open the top cover. (If you have been sewing with the spool, unthread the upper thread back to the guide post.) Wrap the thread the bobbin tension disc going clockwise as you look at the top of the disc. (Bring the thread in front of the machine as you move to the left; then bring around to the back as you bring it to the bobbin winder.) Bring the thread up through the hole in the bobbin. Place the bobbin on the spindle with the hole up. Move the bobbin winder to the right. Hold onto the thread above the bobbin while you start winding the bobbin. After a few turns are on the bobbin, you can let go. After the bobbin is full (or full enough for your task), clip the thread and remove the bobbin. Move the bobbin winder to the left. Tighten the knob in the hand wheel by turning it away from you while holding the hand wheel.
slacken the small stop screw and remove the centre free motion knob. the balance wheel should now be free to turn independent of the shaft. you will have exposed the friction washer. clean all surfaces and relocate the washer with the two locating lugs facing outwards into the two slots in the shaft and refit the knob and screw. if the screw bottoms on the friction washer remove knob and turn the friction through 180 degrees and try it again
If you mean the Singer Style Mate 347, open the face plate and remove the old bobbin. Then, the first step is to hold the hand wheel and loosen the stop-motion screw inside the hand wheel. (Keep the hand wheel from turning with one hand and turn the stop-motion screw towards the front of the machine.) Place your empty bobbin (hole away from the machine) on the spindle near the bobbin winder switch. Feed the thread from the spool on the spool pin through the eyelet on the top of the machine (near the top thread take up) and then down to and around the bobbin tension disc below the on-off power switch. Pass the thread through from the inside of the bobbin to the outside of the bobbin. Move the bobbin winder switch to On and hold onto the end of the thread. Start the machine and let a few winds get placed on the bobbin then stop for a minute. Cut the thread near the bobbin. Restart and continue winding more thread onto the bobbin until you have enough thread or the bobbin is full (it will stop automatically). Move the bobbin winder switch to off and tighten the stop-motion screw.
It is the bit that rotates the bobbin case back and forth in a "shuttle" motion.
It sounds like it would be worth exploring the idea that it is time for a service !!
Remove the stop motion wheel and you will see another part that is loose(looks kind of like a washer with ears on it). Reposition this on the shaft and put the stop motion wheel back on. The stop motion wheel was too loose and it allowed the washer to fall off the shaft. The screw is nice to have and it keeps the washer from falling off the shaft but it's not absolutely necessary to use the machine. Just be caredul when winding the bobbin. sewman7
Dear Jim, I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers. sewman7
