Change resolution
If you read through your HDTVs manual you will find that it only supports FAT32 ~ maybe also NTFS.
Mac OS Extended Journal (HFS+) is a proprietary file system and even a Windows PC can't read it without the appropriate tools or drivers installed ~ let alone a TV.
I'm afraid you will have to reformat your Hard Drive
* This will delete all data on the drive
1. open up Disk Utility (/Applications/Utilities/)
2. select your external drive ("1TB WD Elements" or whatever it is called)
3. click on the Partition tab
4. select the following settings:
Partition Layout: 1 Partition
Format: MS-DOS (FAT)
the name will change to "UNTITLED" but you can change it to whatever you want
click the Options button at the bottom and select "Master Boot Record"
When everything is set click Apply at the bottom right.
Again, this will delete all data from the drive so you will want to backup it beforehand.
