Don't know how.
the Krups instruction manual is useless in this matter but if you do have some mechanical insight this is not very hard. You will need some tools, e.g. an Allen wrench to remove the housing lid.
Anyway, you should not have to clean the grinders very often, perhaps once a year is enough. It depends on the quality of the coffee beans you use; the more 'oily' beans the more frequent cleaning is required.
I would not use water to clean it, rather a small stiff brush (e.g. an old tooth brush), but if that is not enough, water will have to be used.
If so, be sure to assemble the grinder only after the burr is completely dry.
Check the link to Home Barista where a very similar grinder is shown, that should give you an idea about what to expect during the cleaning process.
Good luck;
Villi
Home Barista com
SOURCE: cannot get my krups burr
The GVX2 has two micro switches. one on the top hopper (in the groove on right hand side) and the other in the space the coffee holder (collector) fits into.
The coffee collector micro switch is activated by the lid of the collector.
You have to listen for a small "click" as you place the hopper on and again as you insert the coffee collector.
regards
Philip Williams
SOURCE: Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
SOURCE: Missing user manual
Hello you can download your user manual directly from here
http://www.krupsonlinestore.com/manual/55351.pdf
SOURCE: I have a Krups GVX1 burr coffe grinder.
You will have to disassenble the grinder by removing the screws from the bottom of the grinder. You should be able to get to the thermal fuse once you gain access to the insides.
Well worth attempting the repair if you have the replacement thermal fuse needed and can handle a soldering iron to unsolder and soldering needed to remove and replace the failed part.
The thermal fuse isn't like a normal glass tube automotive fuse, but you should be able to get a replacement one from Radio Shack, if you can't get one from the manufacturer.
Hope this helps you get it fixed and best regards!
the burrs apparantly are are removable as to be replaced by a service center, but there are no instructions as to how to clean the unit, and I might are no instructions as to how to remobe the bean containe; only do not immerse the bass in water which should be the most obvious. also if one is grinding for two cups, how many ounces of water are we talking?
