Question about Syntax Olevia LT32HV 32 in. HD-Ready LCD Television
Display settings went haywire
My LT37HVS TV is having some serious issues right now that I hope someone can help me with. It has been working fine for over a year, but about 2 weeks ago the VGA display turned a pinkish hue. I managed to tweak my
computer's video card settings to compensate for it. But then I found more problems.
The YPbPr1 & 2 inputs went black and white. I figured out that the hue setting had mysteriously reset to 0... and
fixed that.
But then I started testing the other inputs, and found that the picture is jagged and constantly scrolling vertically when anything is plugged into the S-Video or RCA inputs.
The same thing is happening with several devices (Wii, PS2) and with both sets of input jacks. The Wii works fine with the Component input, so I conclude that it's a problem with the TV and not with my appliances.
Has anyone seen this before, and does anyone have any ideas as to what happened to mess everything up or suggestions as to how to fix it?
Thank you,
  • 30 Answers
Re: Display settings went haywire
I had the same problem and in the end it took for an engineer to replace a part at a cost of £120...
Posted on Dec 13, 2008
0 characters
3 Points
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
Feb 01, 2015 | Olevia Flat Panel Televisions
Sharp LC-32SB220U
If you wish to get more details, check this link. Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 28, 2013 | Flat Panel Televisions
How u get it off the **** screen When i hook up my xbox its comes on but its on the left part of the screen & the right side stays blue
Good day!!!
Please try to input other device such as DVD player to determine which device (x-box) or (TV) need to set up full view settings..
If you play DVD and the screen is fine so you need to set up the full view of your x-box using remote..
If you play a DVD but the screen is still half..You need to set the full view of you TV using remote..
I you have more queries and clarification just add a comment..
Hope it helps..
Thanks for using fixya..
Oct 01, 2011 | Olevia LT37HVS 37 in. LCD HDTV
The tv went out one nite and when it came back on it now says no signal... i have a lt37hvs
make sure that the correct input for TV is selected (AV1, AV2, AV3, HDMI, Component etc)
Mar 05, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My tv has the locksystem on and dont no the password need help
314159 is the factory parental code if this doesn't solve your issue then it is most likely set to showroom mode. To change go to Menu>Picture>Mode>Power Up>(change to HOME)
Feb 07, 2010 | Olevia LT37HVS 37 in. LCD HDTV
TV is not coming on anymore
power supply issue whats the model and i will try source a psu and price
Sep 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia LT37HVS 37' was working fine all day and turned to black screen.
It is either the fluorescent backlight source for the LCD panel or its associated power supply failing.
Nov 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Try Shop Jimmy Parts in Ebay stores. Lists parts by manufacturer
Aug 02, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Power Issues for Olevia LT23 :(
can someone tell me what all the different plugs in the back are for???
Jun 29, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Syntax Olevia LT32HV 32 in. HD-Ready LCD Television Logo
326 people viewed this question
Top Syntax Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Syntax Flat Panel Television Expert? Answer questions, earn points and help others
