Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon pixma mp530 problem error code 5100
When I turn on the printer canon mp530, the screen shows CHECK PRINTER error code 5100. Therefore, I cannot print any thing. Please help if you know what's wrong with it and how to I solve this problem, thanks.
  • 14 more comments
  • visexec Nov 26, 2007
    After a paper jam my printer started printing funny - gap down the middle and wavy edges. I cleaned the cartridges and ran align cartridges. After running the align cartridges tool, the same print quality issues were there AND I got the check printer 5100 error. I unplugged the printer and disconnected from my laptop for about 10 seconds then reconnected. I was able to run the diagnostic again partially but got the check printer 5100 error again.
  • Anonymous Dec 15, 2007
    Have MP 530. Error 5100. Moved tank array to right all the way, turned off and on. Now works.
  • RGEof07 Jan 03, 2008
    i turn it on and the check printer comes on and the code 5100 appears so i open everything and check for debris but nothing so i check for something small that may be broken nothing wires,a moving part,inkjet? maybe something needs reset?
  • Anonymous Jan 06, 2008
    Had the same problem, code error 5100, but (also) placed my printing cartridges in the middle and printer MP-530 works now.
  • Anonymous Feb 20, 2008
    yes,I have the same problem.Please can somebody tell me what it's?I don't know what to do and I realy need...
  • Anonymous Mar 01, 2008
    Error Code #5100:
    I have replaced low printing cartridges. I have checked for loose paper or whatever in printer but did not see anything. The COPY light and ALARM light flash off and on interchageably. This all happened when one sheet of paper did not go in correctly but the right side went in first (at an angle) until the printer stopped. I shut the printer power off and pulled the paper out of printer as half the sheet was still visable.
  • Anonymous Apr 09, 2008
    installed printer and unit keeps saying 5100 error how to fix
  • Anonymous May 29, 2008
    PRINT HEAD CARRIAGE RESET BUT GOES ON THE LEFT HAND SIDE AND GIVES ERROR 5100
  • dmcg Jun 04, 2008
    I have the same error message - and my print cartridge will not budge - it appears to be all the way to the right. I have turned off/on the printer, unplugged it, and everything else suggested in prior posts. Any suggestions?
  • rexluv Jun 09, 2008
    I had the same problem on my Canon MP530. For me opening the unit up and moving the print cartridge all the way to the right (and then powering off and back on) did not help. Instead I moved my print cartidge to the middle, powered off and then back on again and that seemed to do the trick. Very strange....
  • trythisfirst Jun 24, 2008
    I had the same problem . . . error code 5100 and lights flashing. I restarted the printed at least 5 times with no luck. It would print a few pages, and then go back into the error mode. Here's how I finally fixed it:
    I turned off the printer and then turned it on to clear out the error. I opened the cover and removed all the print cartridges, as well as the print head assembly (easy to do - just flip the lever up to release it). With everything removed, I turned the printer back on. After the startup procedure, upon prompting from the printer, I put the assembly and all cartridges back in the printer. It then seemed to go into some kind of reset procedure (the magic). After a little while it was ready to print again, and so far no annoying 5100 errors! I hope this helps you!
  • briltje Apr 16, 2009
    ik krijg een foutmelding wanneer ik wil printen of kopieren
    (foutcode:5100)
    mijn printer : Canon PIXMA MP520x
    hoe los ik dit probleem op a.u.b.?
  • Anonymous Apr 28, 2009
    please solution my problem for MP530 canon printers with code eror 5100
    had the error 5100 after paper jam. It turned out that a small piece of paper remained stuck. After I removed it restarted the printer the error was gone.
  • Anonymous Mar 20, 2014
    ink is stuck on right side
    I have turned printer on and off.
    I have pushed the Stop button.
  • Anonymous Mar 31, 2014
    I have a Canon MP530. After cleaning the printer head and replacing it... the printer wont power on. I tried the printer head in another MP530 and the same thing happened... no power. I unplugged for an hour or so and when I plug in again, I hear a very quiet electrical pop and still no power. It acts like there is a short but can,t figure out where it would be. Same thing on both printers now. I leave them unplugged then plug back in and hear the same pop sound and no power.
I had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Posted on Nov 16, 2007
My MP-530 would try to boot up making a noise like something slipping or grinding, ending with ERROR Code 5100.
Solution: Open the Lid. The drive belt was loose and not able to drive the carriage. There is a gear on the right side of the carriage and a pulley on the left side of the carriage. The spring which holds the pulley tight is missing or broken. I was not able to see the tension spring. To put tension on the pulley, to tighten the drive belt, I cut a Popsicle stick into a wedge and inserted it into the middle slot right of the pulley.
Close the lid and power back on. Runs like new. Hope this helps.
Posted on Aug 02, 2009
Hey. I was having the same problem. I tried everything possible. I then grabbed a light took a closer look and I noticed grease on the clear plastic strip. I wiped both sides of the strip clean and so far it seems to be working great. Have printed 28 pages straight so far! Before it would stop after a few or one page(s) printed. Hopefully this helps some of you! Currently I own a mp 500 and 530. Last thing I need is to buy another printer...
Posted on Mar 11, 2009
  • svtrails-tec Sep 23, 2010
    After hearing a screeching noise when the carriage tried to repositioned itself and getting an error 5100, I tried every thing I could think off, but nothing helped. When I read your solution I checked my encoder strip and found found ink on it. I wiped it clean and my problems went away. Thank you so much for this info, I was ready to buy a new printer, I was so frustrated.
In my case (after successful elimination of paper jam with cardboard) the source of error 5100 was ink on the encoder strip:
http://supportapj.dell.com/support/topics/global.aspx/support/dsn/document?c=nz&cs=nzdhs1&l=en&s=dhs&docid=45A49F4D2A17494E8F4B63951C8A1237
Posted on Aug 15, 2010
Solution #8 solved my problem! I noticed there's a black smudge on the right side of the clear plastic strip caused by black ink that overflowed on my CISS. What I did was I just erased it with my thumb and also cleaned the black ink cartridge's gold terminals affected by that overflowed black ink. 'check printer 5100' and 'uo51 check black ink' error was gone! Thanks for this posts and God bless! ---Computerhazard888-sulit
Posted on May 15, 2010
I had the same error code 5100.
After checking the manual I found that the printer carrriage was not moving to the left when I opened the lid. The label on one of the cartridges was lifting up so I removed it altogether, hey presto error code cleared
Posted on Dec 26, 2009
I have a solution!! Buy a Hewlitt Packard Printer
Posted on Sep 11, 2008
  • akwlly4521 Apr 26, 2011
    Not a bad idea! lol...have to say that the HP photo smart my husband has in his office...has NEVER had any issues and is just as old as my mp530, not to mention print quality on photo paper on his HP blows my cannon OUT OF THE WATER!
1st Solution worked great. Thanks!
Posted on Aug 27, 2008
Had to move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Posted on May 27, 2008
2 weeks ago I bought a new MP520. Installed it and printed a test sheet and three photographs and then ERROR 5100
I contacted Canon Support and they sent an Engineer to fix it. It was a simple fix and took less than 20 minutes.
I believe that the MP520 and MP 530 are very similar so this should work,
Lift the lid and behind the Print Carttridge Carriage you will find a plastic strip which apparently tells the nozzles where to drop the ink. Carefully wipe this from end to end with a clean cloth and hopefully, as in my case, problem solved. Good luck
Posted on Dec 06, 2007
Move the cartridge holder back to the right manually, but carefully - close lid and turn the printer off, then on again.
Posted on Nov 18, 2007
Hello, i have an MP-530 and it's doing the same 5100 error, i tried the same procedure you did but its not working, besides im getting an error from the INK WASTE, does any of you have the reset code for this, i'd truly appreciate any info regarding this.
Posted on Nov 29, 2007
  • smashface28 Nov 29, 2007
    I already got the ink waste pads to clean them up and dry them, but as soon as i put them back they're all full of ink, the ink tanks are not leaking or anything like it, but its not letting me do anything with it :(.
    any help welcomed!
  • smashface28 Dec 09, 2007
    I tried to do what u mentioned but it didnt, keeps saturating the pads everytime i start the printer :( any other suggestion is welcomed!
    Thanks though! :)
4 Suggested Answers
  • 1335 Answers
SOURCE: Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
Posted on May 05, 2009
yboyandrei
  • 828 Answers
SOURCE: Canon PIXMA MP180 All-I-One It shows check printer 5100 erros
error 5100, this error appears and the problem is your cartridge, please double check your cartridge is connect properly and if it still have the errors change another cartridge, a new one...
Posted on Jun 22, 2009
  • 33 Answers
SOURCE: error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
Posted on Sep 13, 2009
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error 5100
- Carriage unit
- Logic board ***'y
Sep 13, 2009 | Canon PIXMA MP470 All-in-One Printer
IP90 Canon Printer shows error code 5100: How do I fix it?
This means there is something jamming the mechanism. You should take it to a repair specialist or do your best to check for blockages yourself. It can be the tinest little thing. Check everywhere!
Sep 01, 2009 | Canon PIXMA iP90 Mobile Printer
Jun 22, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Check printer 5100 code in window
This is just a try and error thing ok
Unplug it from the computer and then unplug it from the power
and plug it back in again
Feb 17, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Aug 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon mp180
I had this problem. Removed both ink cartridges and carefully wiped the contacts and print nozzles with a tissue. Re-inserted cartridges and printer now works perfectly.
Good Luck.
Feb 20, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
17,464 people viewed this question
old marine
old marine
