Opened top of machine, applied oil to moving parts
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
SOURCE: need instruction manual for singer sewing machine mod.57825C
Visit us at www.ifixmachine.com
SOURCE: The manual for the Singer 2517 sewing machine says
You can only oil the parts that you can see, if you want to get inside the machine a shop service is best.
SOURCE: Repair manual for a singer model 27 machine
http://www.a1sewingmachine.com/manuals.htm
you can download it free here
