First remove the bucket. Easily clean the filter w/warm soapy water either under lightly running water or carefully gently clean w/towel. Tap lightly to remove any excess water. Place filter up to air dry which shouldn't take long. After putting filter back in, press. & hold the clean filter reminder button for at least 3 seconds.
without the model number I cant be 100% sure , but due to your description of the last thing u did , Id say the light is flashing indicating that the water catch bucket is not installed correctly back as it was before , most units have a safety that wont allow a unit to operate unless the water catch bucket is installed and M/T as this would allow it to dump water to the floor if it were not
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
empty the tank, and clean the dust off of the condenser in the front or clean the filter. if it still won't turn on, may have a bad sensor or a siezed compressor.
E2 Indicates that the filter needs to be removed and cleaned. It's a good idea to clean the filter at least once every 2 weeks, as standard routine maintenance. Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before removing and cleaning the filter. You can access the filter by pulling on the filter frame handle on the right side of the unit, behind the front louvers. You can either vacuum the filter or wash it in warm soapy water (dish washing detergent), rinse it and dry it thoroughly, before reinstalling it. A hand held hair dryer will dry it pretty fast.
The E3 Code, indicates that the air intake filter needs to be removed and cleaned. Be sure the unit is OFF and unplugged before removing the filter. Filter cleaning should be performed at least once every two weeks, as part of Routine Maintenance.
there is a switch that when you put the pale back in the right way if the pale is not in all the way it is a kill switch so no water goes on your floor
