Nick Rogers Posted on Jan 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, My vauxhall zafira CD30: when you insert a cd it says cd error and spits it back out. There are no other CDs in the player that I know of. Any ideas? Cheers, Nick
  • Harrie Jan 19, 2015
    You could be right, but the error in the player can't be that big.
    Sure onbody, not even a child did put something in the player? To make sure, you still have to open it and that won't be an easy job.
Harrie
Level 3:
Top Expert:
  • Master 6,746 Answers
  • Posted on Jan 19, 2015
 Harrie
Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283692
Points
83153
Is that a CD you bought, or a CD you burned? Not all players are compatible with CDR. It should say so on the player, Compatible with CDR. Then perhaps the CD you tried was damaged or was dirty. Or even the laser of the player could be dirty. Don't open the player. There are CD's with a little brush on it, you can use. It costs a few dollar, but it will keep your player in one piece. Hi,
My vauxhall zafira CD30: when you insert a cd  - 25374412-ptmniwyvtjobac0k42nxowvq-4-0.png
  • Nick Rogers Jan 19, 2015
    I only play original CDs and have tried brand new ones and ones that have worked before. If I put a cleaning cd in is it likely to accept it and clean or just spit it straight back out? If the laser is no good, how much is that roughly to replace or get repaired?
    Thanks for your help!
5 Related Answers
Anonymous
  • 112 Answers
  • Posted on Jan 22, 2008
SOURCE: Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
A
Anonymous
  • Posted on Jan 31, 2008
SOURCE: cd player not playing some cds: denon cd player ucd-77
It's not the cds that are the problem as they work in other cd players. Its seems to be the denon cd player itself that doesn't seem to be reading the cds.
Binap
antoniorojas
  • 280 Answers
  • Posted on Nov 17, 2008
SOURCE: M&S CD Player keeps ejecting all cd inserted into player
if you are using good,new,cd,r and no accept try to do this in a room with no light put in operacion the cd player see what happens......if the same time to change for a newone or sendit to repair shop
Anonymous
  • Posted on Oct 06, 2009
SOURCE: NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Anonymous
  • 86 Answers
  • Posted on Oct 09, 2009
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Vauxhall zafira 1 6 fuses
do you know the radio model as there are a few dif types fitted...
2helpful
2answers
My LX d5230 has stopped playing Audio Cd's. It just spits them out showing "Disc Error". Any Ideas anyone?
Hi.
If you get Disk Error only on few CDs, then it can be the media (CD scratched, defective or dirty).
If you get the error on all or almost all CDs, then it is usually because of a lens problem.
You will need to clean the lens.
See the article below:
DVD player in my home theater system won't...
Cd Player in Mitsubishi Lancer not Reading Cds
I have this problem with my car cd player in nissan sentra. You can buy a cd/dvd cleaner and clean drive several times. Previous owner probably put dirty cds in their and the lenses can be very dirty. My cd player would say error and just spit cd back out. Now it works on and off, i think the lense is still dirty in mine. Good Luck. If that dont do it could be something more major with the player.
3helpful
Need instrutions to put the code back into a vauxhall cd30 radio cd player from a 2007 astra. Thanks
Hi with ignition off hold AS button keep it pressed turn ignition on with it pushed wait for a bit then code will appear to entre code you use number 1 to do first code number then number 2 to do second code number then 3 to do third then 4 to do forth then you have to press and the AS button untill the code goes in
2helpful
CD player will not work
some factory radios wont play burnt cds,dont know if thats the case?but i not the case the optcal lens in side the radio is bad got one id sell you out of a 05 ha ha.
Yahoo music jukebox unit error 0x8040410d when burning a cd
When I'm burning a cd in Yahoo Music Jukebox this error apears and I can't finalize the cd.Thank for the future answer.
Marcelo Cesar
Car cd player won't read or accept cds
My chevrolet will not accept the cd...when inserted it immediately ejects...ERR and Radio flash off and on...help
4helpful
3answers
Looking for code for CDR500 ( vauxhall Zafira 2003)
Dear Sir,
We got problem to audio of zafira 2002. we need pin lock code for playing radio and CD player.
thank you for cooperation
Trisno
Jakarta-Indonesia
 Grubhead
Grubhead
SmartAviator
SmartAviator
