Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Lights would not go out,overheated and burned out
Up until now we have not had problems with our FD bottom freezer but the doors were left open overnight and the alarm did not sound and the lights did not go off. The lights overheated and melted their housing and ruined everything in the fridge by warming everything. We had to pry the lights out of their housing and we found the whole housing including the temp control hanging and we could not reattact it to the roof of the fridge. As the warranty expired 2 mos ago we know this housing will cost so we reattached the whole temp housing as best we could as it still works and we are without lights .
2 weeks later the freezer is making a hell of a noise. What now !! its midnight !! Emptied everything and unpluged it and will see if there's ice where it shouldn't be. At least I hope so. This fridge cost a lot of hard earned money and I so angry that I bought junk.
  • HENRY wALKER Apr 29, 2008
    Upon opening the refrigerator door this afternoon, I discovered the light assembly on and the plastic housing distorted from the heat. A check of the door switches revealed that the display (temp etc.) did go out when both door switches were pushed in but the light stayed on
    I removed the light assembly by removing the light cover and the 2 screws. I used a dremel tool to remove the badly distorted area around the screw holes. then I used a heat gun to soften the distorted plastic and returned it to a close approximation of its original shape. I also drilled some holes in the metal cover and plastic shield and used some sheet metal screws to attach them together.
    Upon reinstalling the light assembly, the lights would still not go out. On a hunch, I lifted (tilted) the refrigerator off the floor and let it slam back to the ground. When I pushed both door switched in the lights went out. The problem was most likely a stuck relay.
    Other possible solutions would be:
    Unscrew the light bulbs and leave a flashlight by the refrigerator!
    Call the service guy and pay $$$ for a new light assembly and control board (expensive)!!
  • Anonymous Mar 22, 2009
    The lights in the refer section stayed on and melted the lens and housing twice, I replaced both door switches after the first time.
    Is there a relay somewhere that is causing this?
    Champion:
  • 210 Answers
Yes it is a stuck relay. LG has also come out with a new thermal disk in the light housing as well. This will stop it from melting, but at times you may not have a light on when you open the door. Get the new board and it will solve the problem.
Sgt48
Posted on May 31, 2008
It's the control board, and it will affect more than your lights. Mine started a few weeks ago with the lights (after almost 3 years without a problem) and now it is frosting up in the freezer, causing the fan noise, and we're getting error messages and very erratic cycling of the fans & compressor.
I would call LG to see if they will repair it for you. I asked them whether they could cover the repair since I felt it was a fire hazard, and they agreed to do a "one time" warranty extension. Local repair shop has ordered the parts and I'm just now waiting for them to come in. Good luck!
Posted on Aug 20, 2008
Definitely get the new board. It's a computer board flaw (happened to my recently on my 3 year old LG) and a serious safety hazard. We hadn't had any problems with ours until a few weeks ago. Started with the lights... but now the whole unit has been cycling on/off quickly, we have the freezer frost buildup causing the fan noise, and now we're getting error messages. So it does affect more than the lights.
I saw elsewhere in this site that LG is aware of the problem, and will grant a one time warranty extension to fix it. I called them and they approved it after I mentioned that it's a fire hazard and asked if they would cover it. Can't tell you about the fix yet since parts haven't arrived. You may want to file a complaint with the consumer products safety commission, if enough of us do, we might have these units recalled. Good luck!
I found the plastic part online, and I replace the bulb with LED lights that are only 7 Watts and run cold.  Now nothing can melt no matter what.
Posted on Jul 25, 2008
  • 248 Answers
They have a new main board for this problem. You have to replace board and the melted console parts. Try calling LG. Could be expensive.
Posted on Nov 12, 2007
Bottom mount Freezer Iced up
if you have frozen water droplets on everything most likely the door was left open and when the warm air mixes with the cold air in the freezer this happens,look at the top of the door or the sides of the freezer door,also up on the ceiling where the light switch is,if there's ice there the door was left open,common problem with freezers on the bottom,you can shut down the machine,and with a hair dryer blow the hot air into the vent holes in the back inside wall of the freezer and if ice is on ceiling melt that out too.good luck.
Jul 09, 2012 | Kenmore Refrigerators
Bottom freezer will not open
If you freezer door was left open for an extended period of time the rails that your bottom freezer slide on are most likely frozen. Repair #1 once you get the door open about every hour go in to you kitchen and open and close the freezer door a couple of times. Repair#2 Take your freezer door off remove the rails take a blow dryer and dry the rails untill you do not see any more water then add a sylcone based greast to the ball bearins on the rails and resinstall. Repair#3 Order a whole new set of rails.
Sep 01, 2011 | Kenmore Refrigerators
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Hi. The bottom freezer light won't turn on. I checked the bulb by putting it in another appliance an it wordked. What gives?
We have the same issue with the 22.4 Cu Ft Kenmore elite bottom freezer. Has anyone figured out the problem? Very frustrating..We have unplugged the fridge..nothing. checked to make sure it was getting power to the light socket..all good. We accidently left the freezer door open a little. maybe 15 minutes..we looked and the freezer light came on..closed the door and opened it again, the light still came on..got up the next morning and no light again..Sure dont want to spend $75.00 for a sears tech to come look at it...
Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No air blowing into fridge, although we can hear blower. Freezer is working
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer door was accidently left open for about three hours -- now the top compartment and the freezer are warm -- everything has defrosted -- and nothing will re-freeze -- ice can not be made -- strange...
Switch off the unit at the wall and leave it for a day to cool off. I think your compressor has overheated and has cut out on thermal overload. There should not be any problem with leaving the door open. The problem with the compressor is likely caused by poor power supply or a power surge.
Mar 09, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Subzero door left open - now acting strange
You have probably already figured this out, but if the door is left open there is a sensor that will turn the lights off to keep the fridge from overheating. After you close the door and let it sit with the lights off for 15 minutes or so, the sensor will cool and allow the lights back on. If the temperature reading in the window is ok and does not say "service" or "vacuum condenser", then you should have no more trouble.
May 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
199 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
