Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna Logo
Posted on Jul 07, 2009
Camera shutter won't close - Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jul 07, 2009
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
5132
Points
66
Shutter won't reset after battery replacement
it can fixed only camera fixera company,better if you fix it according to camera company because your problem also be facced to me,i take it to a ordinary camera fixer and then my camera fully get damaged because who fixed my camera they fall acid in battery placce.
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
Hi, I have a F4 one week ago, I've shoot two films, and when i have developed them, i have seen a line of 4 mm wide along the up long side of each photo. Does anybody know what's...
Thanks for the additional information.
Remove the lens and set the camera to manual exposure mode. Select the "B" (or "Bulb") shutter speed. Open or even remove the camera back and hold the camera up to a light source and press and hold the shutter. Look through the camera to see whether there is any horizontal obstruction towards the bottom of the film gate ( = top of negative, they're taken upside down). If you see an obstruction then assess the damage and if it's a foreign body then remove it. Note that you must absolutely not reach through the open shutter. If it closes whilst you have your fingers or tools in the way you will ruin the shutter assembly.
If that test shows nothing, then you really have run out of options and need to send the camera to a service centre for diagnosis and repair. It's likely to be a sticking shutter causing an overexposed band across the negative, usually the width of the band would show some variation in width and position depending upon shutter speed.
A poor battery will not be the cause of a shutter issue. Unless faulty, the shutter will either work or it won't, unlike the previous F3 the F4 lacks a mechanical back-up shutter speed.
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
1helpful
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
I have a nikon N2000 35mm slr, before it was fully functional, now the problem is, The shutter won't open/close but the rest of the camera controls are still functional. Camera wasn't set on B...
So I assume you have changed the batteries and made sure there isn't any corrosion on the contacts. If your mirror is flipping up but no shutter, it sounds like a bad shutter. Check the shutter from the back, then from the front behind the mirror. Look for abnormalities or residue. It is a great camera and uses standard batteries (!) but the 1/2000 shutter has a half life like any other SLR. If you are going to throw it out you may want to open the back and use a q-tip to drip a couple drops of 90% alcohol on the top and bottom (and sides) of the shutter. As a last ditch, I throw cameras or lenses in the toaster oven at 200° for 10 min. and retry (take out batteries and film). At the least it will kill any fungus at the worst it hardens some lubricants. It does make you feel like you are doing some specilized scientific work before you toss it in the trash.
2helpful
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
2helpful
3answers
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
