SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
SOURCE: 42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
SOURCE: Magnavox plasma tv model 42mf230A/37
I guess they are just built to fail. Mine was less than a year old, but they are sending me the exact same unit. Uggghhh
SOURCE: magnavox 42mf230a/37 turns on but no picture or
I have over 10 years experience in electronic tech support.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your TV will have to be repaired.
There is a part that has developed a defect and needs to be replaced.
If you're under warranty or you purchased an extended warranty or service plan, the repair costs will be covered.
If you're not in warranty you'll have to pay for the repair. The cost would likely be a minimum of $300+ for parts and labor. The circuit boards in these new LCDs are not cheap at all! I've seen repair costs averaging $450 and up for large LCD TVs.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
