If i disconnect the fan the beeping stops.I installed a new fan and the same problem occured
SOURCE: "F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
SOURCE: Kitchenaid built in refrigerator controls are beeping
Sounds like a water flow issue. Check to make sure your manifold is getting proper water flow.
SOURCE: We have a Vulcan Bonaire evaporative cooling unit
The problem may be with the drainpump not functioning properly. They sometimes clog up with scale. Easy to remove and clean by opening up the unit. Some units also have an alarm function when the cell pads need replacing. Again this one would be able to see visually. They simply slide out, you would have to locate a supplier and just buy four cellpads.
