Question about Compaq Presario M2000 Notebook
Compo drive doesnt read
My compo drive does not open. With pin I open it. When a CD is in, if asked to open, only the drive letter comes to the screen, as if the CD is empty. I tried cleaning the lens with a soft cloth, still the problem remains. Early the connecting ribbon used to come out and the tray used to get stuck. After pushing back and forth 3 or 4 times only it would close.
  • 574 Answers
Re: Compo drive doesnt read
There is a spring that pops the tray open when the PC releases the latch. you can operate and find the spring or lube the slides with a powderless grease, not graphite as it will migrate to the lens. as fot the hissing, you can look at the direct drive spindle motor and see if it is still physically attaches as sometimes these let go of the spindle. CD roms are not that expensive on Ebay, may be time to upgrade to a DVD while you are at it. CD roms are able to be realigned by a service shop, but may be economically challenging.
Posted on Jan 24, 2008
My compo drive doesnot read attimes .it also produces a hizzing sound .
Posted on Jan 21, 2008
  • 452 Answers
Sir you need to replace your cd drive , it is physical problem of cd rom drive replacement/repair is only solution , out of with repair will be costly and repalcement best solution
Posted on Nov 12, 2007
0 characters
3 Points
Cd drive xhnge
On the front of the CD rom there is a small pin-size hole, carefully put a drawing pin into the hole and it will open the CD drive manually, if it doesn't read disks anymore consider replacing your CD drive
Apr 17, 2014 | MSI PC Laptops
Green light on mains flashes
See link below for chart of diagnostic LED's
Apr 18, 2013 | Gateway nv PC Laptops
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
My cd drive is not working (ACER 5720-4126). and cd drive is not opening which i click button the drive
Try using with safety pin and by pulling the knob
Put the pin inside the small hole on the left bottom of the cd drive
After pushing pin inside the hole the cd player will come out and then Drag it
You can open the cd drive
Nov 26, 2010 | Acer Aspire 5720-4230 Notebook
Hi my cd rom will not read a disc or pop out when I press the button and the light will not come on
to open the cd rom u will need a small pin, there is a small hole on the front panel of the cd rom drive, insert the pin into this hole and the cd-rom drive should pop out...oh and i think you will need to replace the cd-rom drive because its had its best days!
Jul 09, 2010 | Compaq Presario Notebook
I am new too pcs my dell model c640 laptop will it play cds or dvds
Do the following:
1- Right Click my computer.
2- Select Manage.
3- Select Device Manager.
4- Select from the right pane , DVD/CD-ROM Drive.
5- See what comes under it , and read the letters.
CD-R = Only read CD
CD-RW = Read & Write CD
DVD-R = Read DVD & CD (mostly write CD also)
DVD-RW = Read and Write everything Except DVD-Dl
I hope this helps
May 10, 2010 | Dell Latitude C640 Notebook
How to eject cd
If you CD room drive will not eject CD with the use of his button, You use a pin you can see at your CD room drive a small hole use a pin to open your CD room drive. Insert a pin or neddle to the small hole and push. Your CD room will open.
Mar 02, 2010 | Dell Studio 17 Laptop
I can not see the CD/DVD-ROM
Open the administrative tools and go to computer management. Open disk management. Open view, top and hit graphical. You will see the dvd rom drive. Right click on it and select change drive letter and paths. Select and drive letter and it should work. You can read about it in help.
Sep 30, 2009 | Toshiba Satellite A135-S4527 Notebook
My cd draw is stuck in the cd drive. How do i get it open
you should find a paperclip and straighten it out, on the front of the CD drive there will be a small hole just big enough for the straightened paperclip to fit in. Push it in until you feel tension and it should start to manually open.
Sep 12, 2009 | Dell Inspiron 6400 Notebook
Internet explorer 6
i think your ie6 corrupt or infacted by malware.
reset it in internet option in conrol panel.
try to remove it from con.pan. in add remove windo compo.
then install it as same u remove.
then your pro is solved
Mar 25, 2008 | Dell Inspiron 6400 Notebook
Compaq Presario M2000 Notebook Logo
144 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
