I have an old overhead Air handler (mounted in the bathroom above ceiling) and the blower FAN switch is set to AUTO Heat but the fan never turns on...Thermostat has been check but the A/C repairman cannot get the correct voltage from the yellow wire for the coil to kickin and turn on the fan.....He even tried replacing the relay but even with a new relay he had the same problem????
SOURCE: rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
SOURCE: HVAC issues - A/C blows semi-cold air and Heater won't turn on
hi! there,
there are possible cause in the circuit is the thermostat,since thermostat switch is like a switch of light,when this turn on blower and compressor turn on,if you turn on and no cold your thermostat
is defective.replace thermostat,if run but insufficient cold was feel check the operating current,there is a rated current you can compare it can tell if your freon charged is under charged,this should be done by certified service technician from your service center,have inform from your manual the telephone no. and location have it call.if still under warranty claim it have a nice day.
SOURCE: I have an intertherm electric furnace FEH-A020,
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
