I fed our Fellowes C220 with too much paper at once. I have tried everything from using the turbo jam button to putting it into reverse to adding oil to the paper. The paper is stuck at the top and I can see some of it on top of the rollers. Nothing is coming out at the bottoem. I at tempted to open it up, because it looks like I could fix it like that. I would be very grateful for any suggestions.
First unplug shredder. You can remove the top and start removing paper. It can be quite time consuming. I can't remember if this model uses plastic paper strippers or not. If it does, they may have broken when the shredder jammed. They strip the paper from the cutters.
the main drive gear on my universal UNV-38082 medium duty paper shredder is stripped. i need a...
(More)
the main drive gear on my universal UNV-38082 medium duty paper shredder is stripped. i need a replacement or the specifications on the gear to look up a replacement.
we have a Royal paper shredder model number RS9512c. The gear that turns the cutter has several...
(More)
we have a Royal paper shredder model number RS9512c. The gear that turns the cutter has several teeth missing. Where can we get a replacement part?We are in Lexington NC
I wish to examine the motor of an Alko 180HR (which feels stiff to rotate and lacks power) but I...
(More)
I wish to examine the motor of an Alko 180HR (which feels stiff to rotate and lacks power) but I cannot see how to remove the armature. Thanks, Eric
