Tested the spark plug wire with a power meter to see if the coil is firing but no success at that i think the coil is bad but i was told it worked before
Take the spark plug and connect the plug wire to top like it is supposed to be. With plug out of machine rest base of plug against metal of head (anywhere on motor near plug hole) and try pulling fast and look at gap in plug for spark. You have to make sure base is getting good ground to motor but if system working you should see a spark. If not you need to first check for small black wires that come from coil and go to throttle linkage point, or other "kill" switch to make sure the wire did not come off and is touching something. Some machines have a few ways to kill motor with the small wires (like a dead man switch on mower) that need to be checked for possible issue. If the kill systems seem to be working then coil is probably gone. To change coil you have to take engine covers off and pull flywheel to get at coil. You need a wheel puller to take flywheel off. If you have the tools it is not hard but if no tools it is tough.
