SOURCE: Salton Chiming Wall Clock is chiming inconsistently
yes .
check volume setting.
if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
or
if not ok Replace volume control with same type( new one.).
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
SOURCE: the time and chimes are out of sync for our tempus
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
