Vizio E320i-A0 32 Class LED Smart TV Logo
T
Teresa Jaro Posted on Jan 16, 2015
I have the facebook come up on my Vizio smart tv but it keeps saying there is no news feed. What do I need to do?
It says my name and profile it just won't show the newsfeed. Don't know what to do.
Angela Rizzo
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Feb 14, 2015
Angela Rizzo
Contributor
Level 1:
New Friend:
Answers
13
Questions
Helped
2780
Points
38
Look on the top left screen and see if you can click on it and see if it shows that you can click new feed?
2 Related Answers
Anonymous
  • 4889 Answers
  • Posted on Aug 25, 2010
SOURCE: HELLO, I HAVE A VIZIO TV MODEL #VP50HDTV10A IT IS
It sounds like a problem with the power supply board. The part number will be on the board itself. If you can get me that I can help you find a replacement part .
Sai
Anonymous
  • 1238 Answers
  • Posted on May 09, 2011
SOURCE: my vizio tv won"t come
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.
My Facebook page open, but it will not let me do anything, like find. Friends or. Wes feed
Complete your profile first , look at this video tutorial
http://adf.ly/vWHMz
Can't sign into Facebook on my Vizio Smart TV
Log into your Facebook account on a computer. Click the asterisk button on the top far right and click "Privacy Settings." Then click "Apps" on the far left. Click the "Edit" on the "Apps you use" line. Make sure that it says "Platform is On" If not, click the "Turn On Platform" button to toggle it on. Then log off and retry from your Visio TV,
I can't sed message to people on facebook
when youre on facebook go to the menu bar where it says notifications messages and friend requests. click on the message bar and then click where it says 'send a new message' after that you type in the persons name to the smaller box, type your message and click send.
another option is to go to the persons profile that you wish to message and click 'message' the messaging box will automatically pop up
last option is to go to your news feed and right underneath where it says your name and your profile picture (in the top left corner) there is a list of options and you click messaging, type in the persons name to the search bar and youre good to go. hope this helped!
How can i get rid of a facebook connection to a tv show?
Go to www.facebook.com
Login as usual
at the top of your browser window containing facebook.com, there will be
Home, Profile and Account
If its an application:
Left click account, choose application settings from the list of given options.
Find the errant Tv application and press the x to remove it.
If its a news feed: (Typically if you have something in your profile, eg you've told facebook in your profile that you like the show Friends and you now get spammed with Friends updates, a little harder but here we go..)
Beside every newsfeed item there is the option to hide it, click Hide to not show items from that particular entity anymore.
If at a later stage you want them back then using the "Edit Options at the bottom of your news feed page will allow you to add them back in"
If you totally want to remove an item like this Tv show then you would goto your profile and edit your interests and likes.
Delete the offending entry to have it never come back, or from your profile page can you drag the item just below where it is listed where it says "Drag here to hide" this will achieve the same effect as the original method, but allows you to edit more items faster.
Hope this helps
Regards D
2answers
I cannot get the entire news feed and all on my facebook homepage. there is always an error coming. hardly i can see anything done by all my frnds recently. only 3 or 4 posts r visible on my homepage. but...
Facebook changed their site a little bit. News Feed aggregates the most interesting content that your friends are posting, while Live Feed shows you all the actions your friends are making in real-time.
You can control how many friends are shown in Live Feed by clicking "Edit Options" at the bottom of the page.
The News Feed algorithm bases this on a few factors: how many friends are commenting on a certain piece of content, who posted the content, and what type of content it is (e.g. photo, video, or status update).
You can remove friends from the News Feed list (from your default stream) simply by clicking the "Hide" that appears when you hover over their story in your stream.
To add someone back to your News Feed, follow these steps:
  1. Scroll down to the bottom of your News Feed and click "Edit Options."
  2. If you are looking for a friend, scan the list to find that person. If you are looking for a public profile, select the Public Profiles tab.
  3. Click "Add to News Feed" to see their posts again.
  4. Click "Close" to save your changes.
Facebook enables you to see what’s happening with your friends through past events and real-time feeds of information. Highlights and the News Feed were combined into a single stream so that you could have more control over what you view on your home page and stay connected with your friends.
As a result of this change, you’ll notice that the Suggestions section has been moved to the right-hand column of the home page. Also, birthdays and events are displayed more prominently on the home page.
When someone sends you a friend request, public stories about you may appear in their News Feed. If you decline a friend request from this person, public stories about you (stories that have the privacy set to "Everyone") will no longer appear in their News Feed. Please note that News Feed will never show stories that a non-friend wouldn’t ordinarily be able to see. For example, if you posted a video and set the privacy to "Friends," a person who is waiting for you to approve their friend request would not see that in their News Feed. If you had set the video to be visible to Everyone, that person would see it.
You can always change your privacy settings by selecting "Privacy Settings" under the Settings drop-down menu and clicking the appropriate section.
1helpful
Facebook problem: When I log into facebook it doesn't show my news feed at all, I can only see the top strip where it says inbox, profile ect but I cannot few my applications or see my news feed and...
For some reason Internet Explorer doesnt work well with facebook i have had the same problem. Download mozilla Firefox and everything will work smoothly with facebook. Besides Firefox you get less viruses with it. Hope this works for you
http://www.mozilla.com/en-US/firefox/personal.html
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
