Question about HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 all-in-one
Whenever turn on machine all I get is remove and check ink cartridges, have exchanged them with new hp cartridges, put cartridges into another machine and they work, what can I be doing incorrectly?
  • HP Master
  • 1,113 Answers
If I had it, and i was sure that I was using known good correct 56,57 or,58 HP cartridges in the correct slot to suit and cartridge contact membrane on back of cartridge slot was clean and I still found that the HP refused to accept them, then first I would check for a common fault....
Remove both cartridges have a really close look at the bent metal spring wire that sits in both slots, it is hooked on the right hand side of each compartment by plastic tabs and s shaped bend in the wire. I've seen these break at the tabs and then when cart is inserted they put a break in the contact membrane in the back of each slot. - replace carriage assembly
Wow that was hard to explain...anyway what is left is the possibility of a broken ribbon head carriage cable (make sure it is plugged in fully if brave enough to rip apart or it may be creased torn etc, or it could be a board fault, too expensive too fix. So I would send it to heavon..
You could try ebay or something to try to find a old model that suits your new hp cartridges.....
Posted on Nov 12, 2007
Hp 2410 psc all in one has all lights blinking does this indicate that I neeed new cartridge It tells me to remove the right cartridge and then replace it
yes maybe it require to replace the cartridge, but before doing it pls insert the cartridge one by one, i mean put the black ink then observe if the light stop blinking,if yes then the color ink need to replace
Oct 27, 2011 | HP PSC 2410 All-In-One InkJet Printer
My hp psc 2410 keeps reading to remove and check black catridge i clean the contacts, i make reset but nothing. keep saying the same to remove and check black catridge
You could remove both cartridges.
Close cover and turn off printer.
Unplug printer for at least 10 minutes before plugging back into the outlet
Turn on printer and install cartridges.
If this does not correct the problem, the cartridge may be bad.
Dec 25, 2010 | HP PSC 2410 All-In-One InkJet Printer
Remove and check cartridge in right stall help
Make sure that they are new cartridges.
Also make sure, that you took off the strip off where the ink come out.
Then shut if off, wait 15 min, then turn back on.
Good Luck
Nov 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer shows remove and check print...
maybe it suffered loss connection between the printer and the printhead just try to clean it..with alcohol..or maybe you print cartridge has in it's low ink state..
May 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer Cartridges
Try the software ways if the unit is connected with pc ( windows)
Open hp director, Click setting on the top> Then click print settings>Printer tool box> Estimated ink level...
Thats it.....
Dec 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
Printer telling me to remove and check right bay ink cartridge on hp 2410
Just some ideas you probably already tried: 1. make sure you took off the bit of paper / tape covering the vulnerable bits. 2. try another cartridge and/or a friend with similar machine & cartridge 3. make sure you load it correctly: only when machine is turned on, the slight overhang at top each side aligns with grooves, and you are reading the number OK from the front = it is in the right way (deeper end at back). 4. Keep searching different Google reviews and knowledge bases- with different questions.
Jan 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
Not printing text
with a wet paper clean up the head of the cartridge, and let some tint go to the napkin, or paper :) Resulted for me
Dec 21, 2006 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
95 people viewed this question
Ben Johnson
