Nothing, I am just Curious if they will Both work with Each Other through my Computer ?
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
SOURCE: Sony DVD RW AW-Q170A Burning Problem
1. pl confirm ur drive as as sony as AW-Q170A
2. Download both file necflash_wingui.zip and 113bt_rpc1.zip
3. If ur not sure about drive being master or slave turn all the IDE to PIO mode. Pl remember flashing will not be possible if in other mode.
4. Unzip the zip file
5. Run necflash dump the firmweare file at safe location and flash the bin file with 113Bt_prc.bin.
6. Reboot in safe mode. Restore IDE to original mode.
7. Reboot and start normally. Bingo prob is solved
SOURCE: I can't watch a DVD +R on my computer only in a Samsumg dvd playe
it may be that your dvd player may not be able to read dvd+r discs. not all do ,please check your dvd player has the capabilities of reading dvd+r discs.
i.e have you ever watched a dvd+r before on your dvd player?
if it does try getting the model number of it.
SOURCE: Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
