Question about Zenith DVP615 Portable DVD Player
Disk is not spinning in emerson portable dvd
Worked fine, only about 6 months old, on vacation, dvd would start, play for a minute, disk would stop spinning, now not starting at all.
Re: disk is not spinning in emerson portable dvd
If the disc doesn't spin, it sounds like a bad motor. can you hear the laser adjust? if you do, then it's probably a dead motor, if you can't hear that laser adjust at all, and the motor doesn't spin at all, the connection might have come undone(they both share a connection)
Posted on Feb 18, 2008
0 characters
3 Points
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd stops playing and freezes less than 6 months old
Try to use lens cleaner. If lens cleaner doesnt solve the problem. Check your warranty. Or inquire to the store where you bought it.
May 14, 2009 | TruTech PVS12701 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Durabrand portable dvd player motor spin but disk not playing
I have the same problem, the this dvd player i use one time
Nov 17, 2008 | Durabrand DUR7 Portable DVD Player
Will not play dvd
Jul 02, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Apr 19, 2008 | Philips PET724 Portable DVD Player
Dvd player
My worked fine for a 6 months then started reading bad disk even it the disk wasn't.
My solution to problem, buying a more reliable brand.
Apr 01, 2008 | GPX D1816 DVD Player
Samsung dvd-v4600
Wish I could. I have the 4600 combo and the VCR works fine. The DVD stopped working many months ago and just yesterday started working fine again. Worked fine for two days and then stopped, picture froze, and all I got out of it, is the picture is loading. Wont give me back my DVD nohow, so have opened the case and stole it back. Tray will not open at all. Trying some repairs, will holler if succesful
Dec 20, 2007 | Samsung DVD-V1000 DVD Player/VCR
Zenith DVP615 Portable DVD Player Logo
244 people viewed this question
Top Zenith DVD & Blu-Ray Players Experts
Jonathon summesfield
Are you a Zenith DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
