Question about Night Owl Optics NOTG1 Goggles
Detachable head gear for NOTG1 night owl night vision goggles
I need a new A frame face plate and head gear for my night owl NOTG1 night vision goggles where can i get new or second hand
4 Suggested Answers
  • 15 Answers
SOURCE: i need fix night vision goggles
Check l that the HV is present at tube. If it is, suspect tube. If not, check the HV circuit - these vary, but most competent electronics trained technicans should be able to fault find on these.
Posted on Nov 29, 2008
SOURCE: 1 gogle on my an/avs 9 night vision dosn't work
check wiring from tube to contacts on battery pack, normally the issue. There is a soft circuit board in the PAS shelf check the solder joints, they can come off if you have the dual adjustable PAS shelf
Posted on Jun 11, 2009
  • 571 Answers
SOURCE: 2 buttons on my night owl optics nigt vision power
Power = power
IR works only if the unit is on. It will give you light in total darkness for up to some 50-80 yds. With any ambient light at all the IR is useless.
Posted on Nov 08, 2009
  • 2702 Answers
SOURCE: Dysfunctional Night Vision
dont power this up in full day light or you will burn out the ccd pick up if you cant see anything through it i gess the tude has burnt out
its common for this to happen there life span is only about 1000 hours and much less if exposed to bright light, ie minuets!
Posted on Jul 14, 2010
Testimonial: "Thank you. "
0 characters
1 Points
Works sometimes
It could be a lot of things; such as, faulty wire connection, cold solder joint, HV voltage arcing, corroded battery terminals. intermittent short in the switches. If it stop work, try gently shaking it several times, push the on/off button several times. make sure the battery makes a good connection in the battery compartment. Wrap it up and put it in your freezer for a few hours. There are electronic components that might get hot/warm and by cooling them down they will start working again. I don't know who manufactured Night Owl NOTG1 Goggles or who manufacture the components. Rissia manufactures make a lot of night vision devises and components. Also, there are a lot of countries in world that manufacture NV devises, and their parts. GB...stewbison
Aug 30, 2011 | Night Owl Optics NOTG1 Goggles
Repair: Night Owl Lightweight Night Vision Monocular?
First, what are the problems with your Night Owl monocular? I can't help you. You'll need to give more information on what is wrong with the Night Owl monocular. stewbison
Aug 16, 2011 | Night Owl Optics Night Vision & Thermal...
Pls help to find a smiley faces in facebook
Why do you need a smily face on facebook? What kind problems do you have for me referring to Night Owl Optics NONEXGEN-W Monocular. Did you drop in the water and it sank. Come on, give some clarification this. stewbison
Mar 28, 2011 | Night Owl Optics NONEXGEN-W Monocular
My pvs7 wont stay on thay shut of after 30 seconds and then start to shut of ever few seconds
Hello, have you or someone else pointed this night vision devise at bright lights, street lights, head lights. If so, maybe the damage has/hasn't alread been done. STOP. This PVS-7 goggles with ITT image tube with generation 2 or 2+ or possibly generation 3 tube. The devise is an American made unit, and the best in the world. Nobody can compete with the USA on NV. They sat the standards on Night Vision.
Have you replace the 6 volt battery? Get the goggle in a darken room then turn the switch on.
see if the 25mm plate will turn green and stay on. But first replace that battery.
Therefore, if this test works, then never and I mean never shine NV devises into bright lights, it will destroy them every time.
PS. send me another message and let see what happen. stewbison
Feb 26, 2011 | US Night Vision Ultra PVS-7B Goggles
Can I See in Dark Room where light is off. Any device , Camera, Optics are available in market. if available please suggest me. and sent me rates of these.
Hello. only if there are some ambient light source. Very light glow. In the dark room with no light you would be luck see you had. It take light to activate the thin plates in the image tube. Check with Night Owl Optics in El Paso, TX. You can check with the large Optic Lens Companies and see what the have to offer. You'll need to get the diameter of the lens opening, thread size in which it will be in mil-meter mm . stewbison
Jan 28, 2011 | Night Owl Optics PVS-7U Goggles
Not working--see nothing. Do not have instruction manual.
Hello, your Night Owl NOCC3 monocular needs a new image intensifier tube. It is cost prohibitive to have it fixed. Auction it on eBay as "night Vision Night Owl Parts only" GB...stewbison
Dec 31, 2010 | Night Owl Optics Cyclops Compact NOCC3...
Need manual
Call Night Owl Optics in El Paso, Texas. An see if they can help you. Maybe yes and it could be may no from these guys. stewbison
Oct 28, 2010 | Night Owl Optics Tactical NOBG1 Goggles
Need to buy a on off switch search ther catalog thers no parts listing for thease units and not a regular switch and order what you need ther hope this helps
Aug 21, 2010 | Night Owl Optics NOTG1 Goggles
I have a Rigel Optics Night Vision Goggles D2MV- One of the lenses is not working. Where can I send to have it repaired?
Rigel are russian made. You will have to send it to the dealer you got them from. If it is not under warranty the repair cost will be high and you will be better served buying a new unit. If you choose to send them off and you didn't get them from an authorised dealer you may find one of the authorised retailers in your area will do it.....but for a price as they will most likey have to send it to Russia.
Jul 22, 2009 | Night Owl Optics Tactical NOBG1 Goggles
Night Owl Optics Tactical... Problem
you have to focus the blury sides lens and eyepiece
Apr 15, 2008 | Night Owl Optics Tactical NOBG1 Goggles
Night Owl Optics NOTG1 Goggles Logo
49 people viewed this question
Top Night Owl Optics Night Vision & Thermal Optics Experts
Ted Maxwell
Are you a Night Owl Optics Night Vision and Thermal Optic Expert? Answer questions, earn points and help others
