I adjust bobing and timing isawed and needle breaks
SOURCE: needle keeps breaking the top thread...
In general, there are three main causes for this...
wrong needles (Singer), low quality thread (dual duty or all purpose), incorrect threading. Be sure to thread the needle from front to back.
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
SOURCE: Consew 226 breaking needles
I posted an answer to this a couple days ago. If the hook's hitting the needle you need to move it away from the needle. There's a small screw in the bottom of the machine that holds the hook mechanism in place. You need to loosen the screw and gently tap the assembly away from the needle. The hook should just pick up the looped thread as the needle bar rises. You can go to www.consew.com and download a pdf file showing the parts of the machine, also an owners manual. You have to click on the 224 machine. The manual's the same for 224, 225, 226. Or you can click on the 226R-3 - that's the same, too.
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
