I have a wireless network at home (router "level one") and I using a LAN card from my computer, and in "http://192.168.0.1" I have changed the configuration and set a password, and now when I enter he ask username and password buy I didn't set any username. I tried everything: admin, blank, network name nothing works. But i still got an internet connection(and the password for the network). How can i fix that without reset the router. And I need this settings that mean without reset, but any page of the configuration I enter he ask username and password("192.168.0.2/home.htm" "192.168.0.1/Status.htm") so I can't save the settings, please help. And please do not answer "try admin, blank..." because I try it already. Thanks.
Hi
for the username use administrator and ofcourse the password that u have set
cheers
pls rate if it was any help
The most Routers logins and paswords defaults are :admin ___ adminAdmin ___ Adminadmin ____ 1234admin ____ password( blank) ____ password
and other routers you can find a ticket under the router where you can find the pin code and the wireless code and the Administration login and password code .
And if you changed a password and you didn't remember it uuuuh !! so Reset the router to factory defaults :1 - Locate, on the back of your Linksys router, the small button that reads Reset 2 - press the Reset button, Hold for 30 seconds. (till all the leds turns on) yeaah Reconfigure your router on setup wizard by entering to 192.168....
thats all !i!i!i!i
To find the security password for your netgear router please follow these steps,
1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it.
4. In the left side click on Wireless settings , Under
No I told I already tried admin, administrator, black and such stuff
