Question about Canon CanoScan D660U Flatbed Scanner
Canoscan 660u I cannot get the software to instal due to a missing twain driver. What's going on?
0 characters
3 Points
Need Twain driver for windows 7 for canon Scan N12400 flatbeb
The TWAIN drive should be installed when one installs the actual "Drivers" for the unit itself, accordingly I provide you with the download link below.... look for and install ALL drivers and software, especially the Scan manager and TWAIN drivers....
Sep 28, 2011 | Canon CanoScan N1240U Flatbed Scanner
After reformatting my computer I have treid to reinstall the scanner and the software tells me the twain driver is missing. I went to canon website and downloaded the twain driver for the canoscan N670U....
Please check whether your scanner gets detected while connectiNg to your PC. If not please check your cable.Did you down loaded the correct driver that is meant for your OS? Please check. One more thing is the PCB at the bottom of your scanner is getting heated up? Then it canbe a problem regarding your PCB. Just replace it
Apr 18, 2011 | Canon CanoScan N670U Flatbed Scanner
I need a TWAIN driver for a Canon CanoScan N670U
Dear DDuck,
there is no Vista driver for this scanner, thatswhy it is not working with Windows Vista.
Dec 04, 2008 | Scanners
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver." and then download the software "Canoscan toolbox" is the link:
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Cannot TWAIN CanoScan LiDE 500F
What errors do you recieve? Where are you scanning from...what application?
Apr 02, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Canon Scanner - Twain Pilot
QUICK ANSWER: use the original USB cable that came with the scanner.
Using Vista (32 bit version) and a Canon N670U scanner with the new drivers installed from the CanonUSA website. This driver is works for Canon scanners: LiDE 20, LiDE 30, N670U, N676U and N1240U, found at
Canon says it doesn't support Vista 64 bit version. I couldn't get the scanner to work and kept getting the TWAIN error also, despite uninstalling / reinstalling the driver. Finally, decided to disconnect my 3rd party 16 foot USB cable and use the original cable. I swear, it WORKED! I can't explain why, but it did. Perhaps there is increased resistance, hence reduced power going to the scanner by using longer/different USB cable? Anyhow, it worked...go figure. If you have the 64 bit version of Vista, I guess it won't work(?).
Mar 24, 2008 | Canon CanoScan N656U Flatbed Scanner
Need Twain Driver for 660U
Can you take a screen shoot and post here please?And witch kind off canon do you have????
Oct 14, 2007 | Canon CanoScan D660U Flatbed Scanner
Canon CanoScan D660U Flatbed Scanner Logo
540 people viewed this question
Top Canon Scanners Experts
 Mike M
Mike M
D. E. Hev
Mohan Sriraman
Mohan Sriraman
Are you a Canon Scanner Expert? Answer questions, earn points and help others
