My laptop doesn't have a HDMI port so I have to connect with two cables...I think ones VGA and the other is audio. This goes into the back of my old smaller tv...which is ok but I'd like to route the old tv into my bigger tv for watching movies. Is this possible? I've tried using the HDMI cable which doesn't seem to work and also with the three coloured connectors...red, white and yellow. Maybe I'm doing it incorrectly because it doesn't seem to work. Maybe its not possible?
U connect your laptop directly to the large tv for movies. But you have to have the right connectors on both ends to accomplish this. U seem to have an older laptop - if you try connecting it to your newer tv with the outputs on your laptop U may have to get a converter to change the connections to ones that will fit on your tv.
The tv will have either an hdmi input or a simple video input along with audio inputs. the yellow wire is usally reserved for video with the red and white reserved for right and left channels respectively.
Your TV doesn't have video output on either HDMI or Composite video. (There are a few TVs that do have a video out but often that is only available for some input/output combinations. You would need to check the manual but the PC input is usually not available for the video output.)
You could get a VGA to composite or component video converter and direct the signal to your new TV from your PC. One example of the first converter is here: http://www.cablestogo.com/product/29548 . An example of the VGA to component video is here: https://sewelldirect.com/audio-authority-vga-to-component-pc-to-hdtv-converter.asp . There are other models available. A few VGA to HDMI converters also exist. However, since those need to convert an analog output to digital, they are more expensive.
I hope this helps.
(A few VGA to composite cables exist. They will not work for your purpose. They are designed to connect projectors with RCA ports and understand the VGA RGB signal to a computer.)
SOURCE: how to connect pc to sony tv laptop has vga and
hi may that can help you
http://www.youtube.com/watch?v=tkTVzfahNS8
i'm sure this will help youuuuuuuu
please a rate
