actually my combo drive do not read the cd or dvd disc.when i insert a cd or dvd disc into the drive and double click on the cd drive icon only the blank page is open.No files is detected.please give a solutions for this
Two possibilities that are immediately apparent. One, the lens on the
drive is dirty. Stop by a department store and buy a CD/DVD laser lens
cleaner CD and put it in the drive several times, making sure that it
tries to read it each time. This can brush away the debris on the lens
and it may work again. Two, the drive motor or lens assembly (that
moves) has failed. My experience is that these drives have a 2-3 year
life span. Luckily, they are now bargain-priced and you can pick them
up at your local discount store and replace them yourself.
Was this helpful?
Yes
No
Popular Solutions for Acer Internal 24x CD-ROM Drive
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed,...
(More)
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed, I hear the noise of opening mechanism, but the actual plate doesn't come out. Tried to open HP Solution Center, but got the following message: Parsing error in file C:Program filesHPDigital ImaginginhpqsclocC3.xml
I was trying to burn a cd off of itunes but it wouldn't work on my laptop (for a whole different...
(More)
I was trying to burn a cd off of itunes but it wouldn't work on my laptop (for a whole different reason, i think) so i went through a load of programs to try and solve the problem, some of them going through and fixing 'problems' well now i have he cd, off of someone elses computer but now it won't read any disk i put in whether it's a dvd, cd or blank cd. it makes a real little amount of vibration at first but nothing happens. this hasn't happened before... ugh annoying haha. i've tried my comp and looking if there's anything wrong with the drive but it says it's working properly. it's not though as it won't read any disk. i don't know what else to do...
I'm facing a problem with my combo drive in my laptop. When i tried to burn the CD using the Nero,...
(More)
I'm facing a problem with my combo drive in my laptop. When i tried to burn the CD using the Nero, Nero log shows 100% sucessfully burned. After that it checks for data verification, the system looks hanged. I tried to burn the CD without data verification option. The nero log shows that 100% sucessfully burned. But when i check the CD, no data is burned . Pl provide me the support for the same. regards vishnu
(More)
I'm facing a problem with my combo drive in my laptop. When i tried to burn the CD using the Nero, Nero log shows 100% sucessfully burned. After that it checks for data verification, the system looks hanged. I tried to burn the CD without data verification option. The nero log shows that 100% sucessfully burned. But when i check the CD, no data is burned .Pl provide me the support for the same. regardsvishnurvishnudev@yahoo.com
