Back to:
Tags:
Car Speakers and Subwoofers
Generic problem for all Car Speakers and Subwoofers
Wiring speakers to a Saturn
posted by youhokie on Nov 12, 2007
I have a 98 Saturn SL and Im trying to wire aftermarket speakers but unsure of the neg/pos charge of the wires
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 13, 2007
Helpful (85)
valkyrie
Rank:Guide Guide
Rating: 82%, 6 votes
Well, you're in luck. Speakers really don't care how you hook them up so long as they're hooked up. I assume you are replacing the factory speakers with aftermarket, not adding anything new to the system. If that's what you're doing, it'll be a whole new experience. You won't believe your ears, and you won't believe your car could sound that good. More power to you
Rating Locked! (?) youhokie has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Wiring speakers to a Saturn:
I don't want to Accept this solution
Solution #2
posted on Jan 11, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
At least make sure you do it systematically to keep all the speakers in phase. E.g. if one wire is solid and one is striped on each speaker, connect to the same points on the speaker each time, chances are then they should stay in phase.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Car Speakers and Subwoofers problems?
What are the color codes for a Pioneer DSP Audio Processor...
how do I remove my JVC KD-AR880?
my audio player is asking for a code
need wiring system plug in for PRD555
\i have a avh6500 and after putting a dvd rom in . i had...
Loading problems.
Repair Service
Find Car Speaker and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
