Question about Disney DT1350-P 13" TV
How to erase parental control code
Ok ok .... I set the parental code on this tv and used it for several years. The tv was put away and now I want to use it. BUT, Ihave forgotten the code. I've done everything - how do I reset it so that i can watch TV!! My kids must of accidentally set the parental code lock on their TV. It is a Disney Princess TV DT1350-P. I need to know how to reset it.
  • Anonymous Nov 27, 2007
    reset vchip
  • Anonymous Apr 20, 2008
    v chip code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Posted on Nov 28, 2007
**** on the top wire to go to the future, or **** on the bottom wire to go to the past
Posted on Jan 12, 2008
  • Basher_101 Jan 12, 2008
    My dad posted that....what a dick -.-
    Can someone tell me how or please delete it? its irritating -.-
Forgotten parent code for Leap pad 2
If you forgot the four digit parent lock code you set up for the LeapPad3 or LeapPad Ultra, you may retrieve the code with these steps:
1. Using a computer or other device connected to the internet, go to www.leapfrog.com
2. Click "Log In/Register" (or "My Account" if already signed in) on the top right of the page.
3. Sign in with the email address used to set up the LeapPad.
4. You'll land on the "My Account" page.
5. Click "Account Information". Directly beneath the orange "Edit" button you will see the Parent Lock code information for any LeapPad3 or LeapPad Ultra set up using this account
Feb 27, 2015 | LeapFrog LeapPad Ultra Learning Tablet -...
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Both hdmi ports dont work Vizio 50" model P50HDM
Reset Vizio TV default:
1. Press the MENU button on the remote. The on-screen menu is displayed.
2. Use the Arrow buttons on the remote to highlight the Help icon and press OK. The Help menu is displayed.
3. Highlight Clear Memory (Factory Default) and press OK.
4. Enter your parental control passcode. If you have not yet set up a parental passcode, enter the default, 0000.The TV displays, "Are you sure you would like to Restore Defaults? This will erase any custom settings."
5. Highlight Yes and press OK. The TV displays "Memory is being cleared. The TV will reset shortly."
6. Wait for the TV to turn off. The TV will turn back on shortly afterward and the Setup App will begin.
Feb 12, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Jun 17, 2013 | Televison & Video
Ihave an apex TV with the redke
Your TV has been locked. Apex TVs have parental locks that allow you to block certain programs based on their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
If you want more details visit this link. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name first.
Dec 22, 2012 | Televison & Video
How to unlock childs security?
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
Forgot parental controls key
You're going to have to call nintendo to remove the parental controls. They will give you a special code to remove the parental controls.
How to Remove Parental Controls:
Use the information below to remove any Parental Controls that have been put in place.
  1. On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
  2. Select the right arrow twice to reach the third page, then select "Parental Controls."
  3. Select "Yes," to change the parental controls.
  4. You will be prompted for your 4-digit PIN.
    • If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
    • If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    • If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance.
  5. Select "Clear Settings," then select "Yes" to confirm.
Aug 10, 2010 | Nintendo DSi Black Console
Parental Control Password
Use the code 7777 to erase the current code.This will set the code back to the factory default code which is 0000.
Apr 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
How do you reset forgotten parental control password?
try 3308 if not read the instruction manual or telephone them for support
Jan 04, 2009 | RCA HD52W59 HDTV Projection Television
Disney DT1350-P 13" TV Logo
1,696 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
