Microwave Ovens Logo
j
jenn sieg Posted on Jan 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JVM 1440 GE microwave stopped heating. all other functions work great. where do I start
Checked the small white fuse in top right corner-not blown
Pleazer Appliance
Level 2:
Novelist:
  • Expert 150 Answers
  • Posted on Jan 17, 2015
 Pleazer Appliance
Expert
Level 2:
Novelist:
Answers
150
Questions
0
Helped
81362
Points
240
GE microwaves are notorious for the magnetron failing, this is what generates the microwaves. Usually the unit will make a louder than normal deep hum when running if this is the case, but not always. If you have the schematic, you can measure for 120 volts leaving the control board to the transformer, you can simply measure the line in on the transformer for this. You also want to visually note that all other functions like the countdown timer, inter light, turntable, and fan are all running when you start a cooking cycle. The monitor, and interlock switches mounted on the latch assy need to be checked for continuity too. If replacing the magnetron we always recommend replacing the high volt diode connected to the capacitor and chassis ground. Pleazer Appliance...
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 17, 2008
SOURCE: microwave runs but does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • Posted on Mar 12, 2009
SOURCE: How do I change a fuse in a GE JVM 1440 microwave oven?
Remove 2 screws from front vent cover and removed vent cover
Remove one screw from top of display
Gentley push display panel up about 1/4 inch and tilt the top toward the front.
Disconnect 3 thin gauge molex connectors
Disconnect 1 heavey gauge connector
Remove screw from grounding wire at botton of display curcuit board
Remove display panel completely
Remove grill from above display area
To the left is a 2 x2 inch square board
Coil, capacitor and fuse block
Remove fuse
Check fuse rating
Match fuse rating and replace
btrossman
  • Posted on Dec 24, 2009
SOURCE: GE Spacemaker microwave XL1400
If everything else is running but the food is not heating, the microwave generator is shot and needs to be replaced... Unfortunately, you need to be certified in handling the units so the average consumer cannot buy one (at least not as far as I could find when I had to replace mine) .
Will cost $150 to $200 so unless you have a pretty fancy microwave it will probably cost less to just replace the whole darn thing - So much for going green!
Anonymous
  • 43501 Answers
  • Posted on Aug 07, 2010
SOURCE: Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
paulcrissman
  • 55 Answers
  • Posted on Sep 09, 2010
SOURCE: microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Basic Microwave Oven Troubleshooting Tips
heatman101
It does everything except heatinig up food. Model # JVM 3660 SD 001
The magnetron is not working. This open it and check to see if it has a blown fuse. Some microwave would have seperate fuse for the heating power. If fuse is good. You may be able to get a used magnetron from another microwave. Somtimes pawn shops would sell microwave for 5 or ten dollars just because it doesnt have a turnplate inside.
1helpful
Microwave blows fuse in microwave mode grill function ok
Microwave Oven has no power.
yeah open the microwave, and you will see a fuse usually located on the top area. the is also a fuse around the back of the panel area.
My GE spacemaker JVM 1440 Watt microwave has F4 error code.
Have GE JVM1440BH light and fan that are operated by the touch pad do not work. Both stop working at the same time. Ideas????
1helpful
Microwave does not heat
un plug remove cover find red lead to magnetron with thick long plastic round blob this contains a long glass metal ended fuse that has probably blown due to running when empty long fuse is necessary to stop hi voltage flashing over airgap when fuse blows when fuse blown no output from magnetron as hi volts missing steve t
1helpful
3answers
GE Profile Microwave oven
ge microwave fuses are behind upper grill and behind right side grill
Works but no heat
Possibly a blown fuse inside, or a defective magnatron. If you decide to open the unit, please unplug it first!
Geno
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
