Tried disconnecting power - no help
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
SOURCE: 5-inch black horizontal line across screen
Unplug the tv wait a minute .Plug it in turn it on see if that fix the problem. these tv are computers and can go hay wire.just like a computer ,some times a reboot will fix things for a while.make sure you have a good clean source of power at the receptical and your not having power spikes or drops . Good Luck!
SOURCE: Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
SOURCE: TV wont turn on--power light blinks but no picture
The problem is in the power suplly board.In the LCD TV this board is common to the rest function.If the reparation cost is 80% on the new LCD I suggest to buy one new.
SOURCE: My 2 year old 37in Toshiba 1080 LCD HD tv has a dark shadow
it sound like one of the drivers is going out, not much you can do with out service
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
