Question about Whirlpool GEW9250 Electric Dryer
Not getting any power at all from whirlpool duet dryer gew9200
The dryer is not getting any power at all. when i press any button it does not do anything.
  • 5 more comments
  • Speedball Nov 14, 2007
    My dryer does the same as well. None of the lights come on when pushing buttons on the control panel, however the light comes on when the door is open. And yes, it is plugged in. What should I do?
  • Stillwet Nov 18, 2007
    I have the exact same problem as "Speedball." Light's on; nobody home.
  • Tickhll Dec 13, 2007
    I have the same problem with my GEW9250PW dryer. Light is on inside the dryer but none of the controls are working.
  • mkvick Feb 06, 2008
    Drum light works, panel does not.
    This happened after we lost power to our house and the power was restored.
  • Anonymous Oct 31, 2008
    Same problem. Some of the small lights are on too, but nothing of course works. Repairman said it's the computer inside the control panel, part is costing us $298.00. On top of it, there is nothing to prevent this from happening again - it can happen anytime there is a power outage, and you cannot use a surge protector with the dryer plug.
  • ohembe Jan 22, 2009
    I just got my Duet Sport today and the guys hooked it up. Plugged it in, inside light worked but control panel didn't.
  • Anonymous May 19, 2009
    I have an older whirlpool dryer. The dryer is not doing anything at all. When I push the button it does not do anything.
  • 4 Answers
When we got ours it had the same problem. A service call would have taken days so I simply unplugged the unit (safety first!), and removed the top (a number of sheet metal screws). In the front left I noticed a couple of "ribbon" cables and one was hanging loose (obviously NOT connected). I looked around and located where it was supposed to be connected and snapped it in. Plugged the unit in and Voila! all worked. Unplugged unit again, put the top back on and everything has worked since then.
ONLY DO THIS IS YOU HAVE THE TECHNICAL EXPERTISE AND MAKE CERTAIN YOU UNPLUG THE UNIT BEFORE ANY ATTEMPT.
Posted on Nov 23, 2007
How can I get my dryer running?
You need a new machine control board
Oct 02, 2016 | Whirlpool Dryers
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
My control keys are locked
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
May 16, 2010 | Whirlpool WED6400S Electric Dryer
Where is my heating element located?
Remove the access cover in the rear, and it will be right there in front.
Jul 26, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
402 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
