Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Here's how I fixed mine with Win-VISTA: 1.Click START 2.Click CONTROL PANEL 3.(Switch to CLASSIC VIEW) a.Click on SOUND b.Click on PLAYBACK Tab c.Click on SPEAKERS/HEADPHONES d.Click on PROPERTIES e.Click on CUSTOM Tab i.Make sure PC SPK MUTE is NOT checked f.Click on LEVELS Tab i.Slide PC SPEAKER to 100% ii.Don’t worry about the SPEAKER slider, it’s controlled by the keyboard buttons g.Click on ENHANCEMENTS Tab i.Make sure LOUDNESS EQUALIZATION is checked h.Click OK i.Click OK 4.Close CONTROL PANEL
Make sure you didn't accidentally hit the lock button. Unlock the keys by
pressing in on and holding the Volume/Scroll/Select
dial until the lock icon disappears.
You need to go into programming and turn cid on for all co lines on your c1 card and on all ext's that you want to show cid on incoming calls. Follow these steps :
to enter programming, you can use any display phone. Without picking up the handset.
press transfer
dial 800
passcode = 4321 (if it has'nt been changed)
press 1
press the speaker btn
dial 312
you will see 201 . press the ans/rls key, this will change where the 201 was to all
use the volume arrow up to change to CID ALLOW
press the right softkey (this key is the triangular key under the display just to the left of the scroll key.
Now, press the speaker btn and dial 414
you will see 701 in the top left of the display .
press ans/rls key. this will change 701 to ALL
press the volume arrow up to change from normal to cid trunk
press the right softkey under display .
press transfer to exit programming and you should have
Caller ID.
1)First check the mute. 2)Make sure there aren’t headphones plugged in, that will disable the speakers. 3)Check the audio setup 4)Check your Volume lock
Changing Volume Lock The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to set its volume control for independent operation or Global Volume Unlock to remove all volume locking. Locking Volume Control to One Mode (Global Volume Lock) 1. Press and hold SET until the red LED blinks twice; then release. 2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example, TV) will control the volume regardless of the current mode. Unlocking All Volume Control (Restoring Global Unlock) 1. Press and hold SET until the red LED blinks twice; then release. 2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now independently controlled for all programmed devices. Unlocking a Single Device’s Volume Control 1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX). 2. Press and hold SET until the red LED blinks twice; then release. 3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now independently controlled for the selected
