Philips Magnavox DVD/VCR Dual Player Logo
Problem with Philips Magnavox DVD/VCR Dual Player
error code e25 magnavox dvd recorder
whenever i try to record to a blank dvd (vhs dubbing or otherwise) it gives me this error code and records 3 seconds. even on home movies.
Posted by avatar on Jul 07, 2009
Suggested Solution (3)
You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
  • by Author image tragicirony9 Over a year ago
Source: dubbing VHS to DVD
Was this solution helpful?
No
Yes
Are you pressing the record button on the actual box? I'm not sure if you are supposed to be able to record that way, but I can't either. If that is what you've been trying, then I suggest this:
What I had to do was hit the "Dubbing" button on the remote control. It will automatically start the VHS tape and start recording to DVD.
Hope this helps.
  • by Author image lydiak122 Over a year ago
Source: zv420mw8 magnavox vhs to dvd recorder
No
Yes
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
  • by Author image dafid Over a year ago
Source: Error code E 4 54040990
No
Yes
Tips for Helping tuckersaspy With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
See all Philips Magnavox DVD/VCR Dual Player Problems
