my ilo 26hd tv broke down right after my 1 year warranty with the manufacturer, when i try to turn it on just the blue screen appears and says no signal, i cant change channels or volume or component or nothing not even with the control. Does anyone know what is wrong with it? Or does anyone know how much it cost to repair? Does anyone repair?.
Got myILO 26HD as prize from 7-11 grand opening.
Worked as my computer monitor for 10 months.
Now I get Blue Screen at HD with "no signal" message. No response to Remote or controls on side of TV.
I have no receipt so am SOL.
j5texas@msn.com
Comment by Guest, posted on Nov 24, 2007
MY TV IS STUCK ON ONE CHANNEL IT TURN ON AND OFF BUT IT WONT CHANGE CHANNEL
Comment by Guest, posted on Nov 16, 2007
Same thing happed to me
I spent $600.00 for this puiece os S$%^&^ get a lawyer
There are tons of threads concerning ILO tv's not working. Sent ours back TWICE with the same problem.... no buttons on the TV work. Walmart will not accept these TV's back and ILO can't fix the TV's. We need a class-action lawsuit against this company. People are having the same issue with the 32" tv's as well.
We bought one as well, sometimes it comes on and sometimes it don't. I think walmart needs to refund our money. They knew they were a bad deal since they don't even carry them anymore.
Comment by jazzy47, posted on Dec 29, 2007
Me again, when the tv comes on, which takes some maneuvering with the buttons, it runs and shows a good picture, just when you turn if off you don't know if it will come on again or not. I am really regretting buying this tv now. Walmart should stand behind these as they were made just for them... I agree, something needs to be done, either replace with a different brand or fix these or refund money spent on them.
Rating Locked! (?) ylcastro has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ILO 26 HD TV:
Me too, me too!
Same problem.
I won the TV at a 7-11 grand opening.
It did not work well with my TV antenna (don't have cable or satellite).
Instead I used it as computer monitor. There was a DVI connector in back of the TV.
It worked well, though sometimes I needed to use the remote to change the TV from DVI to HD mode and back to DVI to get the display to work.
Recently I turned it on and got a blue screen on the DVI screen. There is a message of "no signal". It would not respond to the remote or the control buttons on the side of the TV. I hooked it up to my DVD player and got the same response.
I guess I was lucky. I had use of it for almost a year. Others I have seen have problems afterr only a few months. It is hard to return to my "comparitively" little 17 inch monitor.
Was this solution helpful? Show your Appreciation by rating it:
