Question about AcerView 54EL 15" CRT Monitor
Acer crt monitor
Sir i have a acer crt monitor model no CM-1448N the E.H.T. is faulty but i am not able to get it and i do not even know its no.... sir can u tell me the E.H.T. no and it's equvalant no please i am form bombay india .can u tell me from wher can i get it ???....
2 Suggested Answers
  • 98 Answers
SOURCE: CRT Voltage Pin Voltage
What is the problem? Can't fix without info.
Posted on Dec 25, 2007
  • 32281 Answers
SOURCE: i m having acer ac515 15
Any crt monitor will work with your computer.
I suggest you get a LCD monitor instead and a larger screen than 15".
LCD screen take up less desk space and are lighter and more energy efficient.
Posted on May 22, 2010
0 characters
1 Points
Hi gud evening sir , iam using samsung sync master753s , all of sudden display colors are faded, i tried to unplug all cables but its again same problem, please tell me the solution
Unfortunately, this is a extremely common problem with all samsung CRT monitors. I do not think there is a fix; You have a bad Cathode Ray Tube. You need a new monitor. Sorry! Dont forget to rate
Jan 13, 2011 | Computer Monitors
My acer AC713 monitor's brightness value gets reduced to zero.
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
Sep 10, 2009 | Acer AC713 17" CRT Monitor
If you are talking about a burned in image on a CRT screen, there is nothing you can do about it, except replace the picture tube, which usually costs much more than to replace the entire monitor.
Jan 27, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
How to replace flyback acer 14' 11d
hi there, there is a part number of the flyback at the body of it and you can repalce it by telling to the store the number of the flyback transformer. ty
Dec 24, 2007 | AcerView 78ie 17" CRT Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Monitor VM-9AF problem: display a smaller image as the screen
computer comes on , monitor has blinking light but come on with computer
Jan 06, 2007 | Boundless Technology Tatung VM 9AF 9" CRT...
AcerView 54EL 15" CRT Monitor Logo
32 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
