Okay, I've just joined and I'm hoping someone can help. So tonight, I plugged in my iPhone to the left usb ports (as I always do before bed)(The right ones are disconnected for some reason, I think the wires are broken). A few minutes later a pop-up down the bottom said something about the ports not working any more. I love this laptop, and don't want to replace it or pay heaps to get it fixed. Any help is greatly appreciated :)
    Top Expert:
  • Computers & ... Master
  • 29,937 Answers
I expect the iphone has overloaded the USB supply. The current the ports can supply is limited and will stop working if overloaded. Use a powered USB hub or the iphone charger. Your motherboard may need repairing now.
Posted on Jan 13, 2015
SOURCE:
shivam4529
  • 150 Answers
SOURCE: My laptop won't connect to wireless internet...
It seems the two oval lights on the front of the Acer TravelMate 3003LCi are not only lights to indicate WiFi traffic, but also buttons to turn the WiFi radio on and off for security reasons. If you press and hold the left side button for 3-5 seconds it should turn back on the WiFi radio. Windows XP (and maybe other OS’s) have a power saving function that turns the radio off when not in use to save the battery, so you have to use the buttons to turn the radio back on. Seems like a pain in the @$$ to me, but it’s a clients laptop not mine so he will have to live with that.
I hope this helps someone so they do not have to go through the frustration of trying to figure out why the radio has been turned off.
Posted on Nov 15, 2007
  • 198 Answers
SOURCE: Computer not recognizing any usb devices
Well, appears that your configuration can handle 4 GB of memory. I checked the Acer website for upgrades for your model, and nothing appears to jump out which could solve your problem. A few appear to be possibly helpful, but some are for XP, not Vista. Upgrading "launch manager" might be a good thing.
However, Belarc tells me that on my Acer 5630 i have listed under "Bus adapters" the following:
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
And, under "other devices", i have a USB Root Hub (5x). Obviously, the two match. I go to device manager to check them out, finding them under 'univesal bus controllers", to see whether they are all working properly, and and they are. In addition, opening "system devices" reveals something called a "plug and play software device enumerator", and that checks out to be working fine as well. Check your equivalent out to see if you find a problem to fix. Hopefully you will. Let me know how things go.
Posted on Apr 23, 2008
Pyrhyc
  • 2028 Answers
SOURCE: replace broken usb port on dell latitude laptop
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Posted on Jul 27, 2008
SOURCE: CL51-15 USB Port Problem
I was hoping you can help me out guys, i have this laptop acer travelmate 290 and everything seem to be working properly. All the drivers and devices are installed and working fine(Audio, Display, Network, Wireless, PCMCIA......) except my 2 USB port. I tried almost all devices on it but nothing works and cannot be detected at all ( mouse, keyboard, cam, printer etc...) Device manager say's my usb port is working properly and has no conflict at all.
OS : Windows XP Pro /SP3
USB Controllers
USB: Intel(R) 82801DB/DBM USB 2.0 Enhanced Host Controller - 24cd
- ...... 24c2
- ...... 24c4
- ...... 24c7
- USB Root Hub.....
Everytime i plug something on the USB port i dont see any respond at all, like new usb device was found or somethin message pop up on the lower left on my screen. Nothing at all.
Hope you can help me out guys
Posted on May 21, 2009
  • 26 Answers
SOURCE: Can I power my laptop through th usb port
I know you've either fixed your problem, or thrown the laptop out(still a "fix") but for posterity, and for anyone with a similar problem...
There are two answers, depending on your laptop.
First, NO, there is currently no way to charge your laptop battery by putting power into the usb port.
There ARE commercial external batteries. sadly, they will connect to your failing power-socket.(see http://www.laptop-battery.org/Power/External-Batteries/ENB003L.html)
If your laptop has a external battery charging dock, for spare batteries.... you could go that route.
you'd probably still want to follow the last suggestion.
GET IT FIXED!
Seriously... anyone with fairly good soldering skills can probably fix that powerjack. It probably pulled/pushed the traces off the main board and will require superglue, solder, and maybe a bit of fine wire, to fix. The biggest obstacle will be the dissassembly, and proper reassembly of the laptop case. It'll take a while, but once fixed, should return your laptop to 100% functionality.
I have saved 3-4 laptops with this technique. One, I even swapped the power jack to a more common size. This was to allow the use of a non-proprietary power brick(the original had fried itself).
Posted on Jun 18, 2009
Can u show with picture how to join playstaion gamepad into usb input
Hi
The joypad plugs into one of the USB ports on the front lower left hand side of your console
Hope this helps Nick
Dec 30, 2017 | HOW Video Game Consoles & Games
Onkyo standby
I have the same problem. Haven't exactly timed it, but at some point, my TX-SR309 always shuts off by itself when playing music from my iPhone connected in the front USB port. Hopefully someone has a solution for this.
Jan 27, 2014 | Audio Players & Recorders
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
Gaming mouse cannot detect
try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
Jun 13, 2012 | Computers & Internet
I plugged my Philips 4GB GoGearVibe mp3 player into my computer to charge but i am not sure if i plugged in all the way. This has happened before where the battery died but came back when my dad charged...
if you are charging via usb make sure you have the computer (if its a laptop) plugged in and if you are using a pc make sure your using one of the usb ports on the back as some usb ports will not carry the 5v needed to charge your player.
Mar 27, 2011 | Philips SA5125/37 MP3 Player
My iphone not charging and on..help me!! :(
1. Check your charger with another iPhone. If it is working, your battery may be dead. If not, replace the charger. You can buy some at www.amazon.com or any other site you like. 2. Try charging the phone on your laptop via USB cable. Hope this helps. If so, please rate. Thank you
Jan 15, 2011 | Apple iPhone Smartphone
I have a Samsung HM060HI hard drive from my laptop, The laptop is wrecked, I have removed the hard drive... Is there any way of getting my data (pictures and files) from the hard drive by a lead that joins...
You can always use an external Hard drive enclosure whose SATA interface communicates with your computer using your USB ports... 1. Purchase/borrow the enclosure 2. Insert your Hard drive 3. Plug into your USB port 4. let the drivers install and begin migrating your data
I hope this has been informative...
Nov 21, 2010 | Samsung HM060HI Hard Drive
Usb port refuses to recognize plug in hardwares,
You can check from the Device Manager and see if you can enable it from there. Right click on your My Computer and choose Manage. On the left panel click on Device Manager. From your right, expand the Universal Serial Bus controllers. Right click on each on the list and choose Enable.
Also so you can go and check on your BIOS settings and see if the USB port is enabled.
Goodluck and hope this helps.
Oct 27, 2009 | Acer Computers & Internet
Iphone 3g error 13
Hi friend:
Don´t use front USB hub from computer.
Try rear USB ports.
If you are using laptop, try on diferent computer.
Regards
Aug 19, 2008 | Cell Phones
3680 2682 Laptop fell off bed to floor w/ USB drive plug in back
hi, if the port is working fine, its ok.. but do not use this port, since its damaged, it could short the pins inside while pluging the cable, left side is better
Jan 03, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
Alun Cox
