IT MAY BE A DEFECTIVE KEY BOARD IT HAPPENS NOW AND THEN. MAKE SURE THAT YOUR CONCECTION IS TIGHT. MAKE SURE THAT YOUR ELECTRICAL CORD IS TIGHT INTO THE ELECTRIC SOCKET. YOU COULD TRY CLEANING OFF THE KEY BOARD OR BLOWING IT OUT TO MAKE SURE NOTHING IS STOPPING THE KEYS FROM WORKING. MAKE SURE NO BARE WIRES. THERE COULD BE A VERY SMALL PIN HOLE IN THE ISULATION AROUND THE ELECTRICAL CORD.
SOURCE: microsoft blue tooth 5000 mouse stopped working
Deleted the mouse from bluetooth and then added again.found info at
http://support.microsoft.com/kb/894035/#top
SOURCE: my dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
SOURCE: my dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
SOURCE: Product installed correctly as far as I know.
First, try replacing the batteries with fresh ones.
Then, hold down the connect button on the receiver and on the keyboard (usually located underneath) AT THE SAME TIME for five (5) seconds, and then release them both.
Try using the keyboard.
If same problem occur, try connecting the receiver into different USB ports of the computer. Or might as well, try different computer.
SOURCE: Cannot connect to my MacBook Pro. My Mac Mouse
you need to install keyboard driver for your macbook
