Question about Compaq Keyboard
Compaq keyboard model # 101-p01 : sometimes i have to press a key two or three times to show on screen. no certain key, can be any key on the board.
  • 143 Answers
SOURCE: compaq e500 keyboard driver
Here is the link for the e500 Keyboard Drivers select the operating system〈=en&cc=us
Posted on Jun 19, 2009
0 characters
1 Points
Where is the Scroll lock on the keyboard of lenovo laptop?
To Turn on/off Scroll Lock do one of the following: Press the Scroll Lock (sometimes appears as ScrLk) key on your keyboard. If your keyboard does not have a Scroll Lock key, on your computer, go to Start, All Programs, Accessories, Ease of Access, and then click On-Screen Keyboard.
Jul 14, 2014 | Compaq Keyboard
Cannot change the function on my keyboard back to a question mark
If you're on Windows then try pressing CTRL+SHIFT keys together (sometimes ALT+SHIFT, see which combination works for you) until your keyboard layout indicator in your system's notification area (bottom right part of your screen, just left of system clock) shows the keyboard layout code that you're used to, in your case "EN". You can cycle through all the installed keyboard layouts using this same key combination.
Mar 02, 2012 | Compaq Keyboard
My Acer key board can not display the at sign above TWO key shows inverted commas instead and the hash sign above THREE shows a Pound sign? Please assist
Hold down the ALT(ernate) GR(aphic) key -- to the right of the SPACE BAR on your keyboard.
Press the '2' key.
Release the '2' key.
Release the ALT GR key.
Does an '@' display?
Check that you are using the "American English" keyboard mapping.
Control Panel -> Regional options.
Mar 06, 2011 | Acer NSK8458AN Keyboard
Keyboard works for windows password only.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Dec 18, 2010 | Compaq Keyboard
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
Keys not working
Try to unplug the keyboard, restarted the computer and reconnect the keyboard once the computer is fully restarted.
Then go the Control Panel, double-click the keyboard icon. Select the Hardware tab and make sure that the "Standard 101/102 key or Microsoft Natural Keyboard" is highlighted or selected.
Aug 17, 2009 | Logitech 967233 Keyboard
Keys on laptop not working!
the keys type numbers instead of letters, help!!
Aug 01, 2009 | Acer Keyboards & Mice
Microsoft wireless keyboard 3000
Once I take the keyboard apart, and brush off the 3 plastic layers underneath the keyboard, it works fine.
There are 14 screws on the back that you need to remove, a couple of them are hidden underneath warning / instruction stickers so you have to feel for them and cut the stickers off with a knife.
Sep 14, 2007 | Toshiba G83C0001K210 Keyboard
Keyboard does not work
don't think this is caused by the game install shut down the pc and remove the battery and charger for a few minutes. Boot it and try again try connection an external keyboard
Sep 11, 2007 | Gateway 2520915 Keyboard
Compaq Keyboard Logo
106 people viewed this question
Top Compaq Keyboards & Mice Experts
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Keyboard and Mice Expert? Answer questions, earn points and help others
