Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
3-D Screen The picture seems to be 3-D and show three different colors all like shadows of each picture. I have an old Toshiba Theaterview TP48D50 Model and Chassis # TAC9491. Any tip/solution would be appreciated...
You need to replace the convergence IC`s and check for any bad fuses and burned resistors near the chips. The convergence chips are mounted to the big aluminum heat sinks.
Posted on Nov 12, 2007
I have a toshiba 62mx195 with a bad light engine does anybody repair light engines?
Hello
Im having problems with my 62mx195.
The I have a good picture but i have shadows next to or on certain objects. It occurs over the whole screen at different scenes of show. There are blue shadows that pop up intermittently. I have tried hooking up different DVD players to the TV to see if there is a difference, but nothing. It seems minor but it annoying as hell. I hope it is not an Light Engine.
Nov 21, 2009 | Toshiba 62MX195 62" HDTV
Objects are shadowed on screen and color seems to be seperating
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 30, 2009 | Toshiba TW65H80 TV
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
Mar 13, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba theaterview
What is the model number?
Jan 03, 2008 | Televison & Video
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
