Hello, I print labels for my products via the thermal 2844 with a 2 by 4 inch label. For some...
(More)
Hello, I print labels for my products via the thermal 2844 with a 2 by 4 inch label. For some reason yesterday it started printing from center to right and half my barcode is missing with price. This is a problem, now I can't scan my tickets. Can anyone help allign this and fix this issue? I use this printer with my POS system but in settings of my POS it takes you dirrectly to the settings of the printer and I get lost from there on.
We are in need of thermal printers and Zebra LP 2844 was suggested - what kind of thermal label...
(More)
We are in need of thermal printers and Zebra LP 2844 was suggested - what kind of thermal label needed: is it the one with i-mark (black squares at the back) or the one without the i-mark?
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each...
(More)
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each label. First one print all right, but next ones are not on the tag, printer leaves some gap. i have removed gaps between labels as well in printer properties, but still nothing. please if you can let me know how can i calibrate jewellery tag in tlp2844 Thanks
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to...
(More)
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to print the same bar code horizontally it does not print all the lines. Thought I had printer head problem but the same happens with the new one.
