Sounds like the water damage has killed the computer ,what i suspect is that the water ingress wasnt completely dried out and the circuit board was damp ,well it worked but the damp circuit boards have now burnt out owing to the electric passing through them ,so its a complete renewel i should think
SOURCE: wont start, no faults on ecu,keeps flooding,
Sounds like the old nikasil problem.Remove all of the spark plugs and squirt oil down each bore,replace plugs and she should fire up.
SOURCE: Wet carpet under front Passenger seat
You have drain blockage in the condesor case itself. There is a small tube that will drain the condensor case, the big black plastic case that contains most of your a/c system inside the car. This case collects moisture and that must drain normally from the case drain to the outside of your car onto the ground.. If this drain is plugged, you will have leakage on to the floor. If the moisture is allowed to remain in the carpet, mildew will set in and then you will have to replace the carpet.
Bill
SOURCE: Audi 2005 A6 4.2 Flooded cabin,Navigation not working....help!
I had a similar problem, the cabin flooded and destroyed the computer under the seat. UK car 2002 2.4 v6. There seem to be several spots to check. Remove the grommet in the metal work under the battery to allow water to drain. Check plastic strip on the lower edge of the windscreen is clean and fitting snugly against the glass. Clean out old leaves etc. And check that all is sound around the aircon filter. Good luck.
SOURCE: Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
SOURCE: Soaking wet floor mats - '98 Mazda Protege ES
drain pipe from the interior ac unit ,look for rubber outlet pipe outside firewall passenger side and unblock the end
